Fuel optimizer
Discussion in 'Schneider' started by dieselfuelonly, Feb 3, 2014.
  1. dieselfuelonly
    dieselfuelonly Road Train Member
    2,475
    5,086
    Nov 12, 2012
    Chapel Hill, NC
    Is there any way I can tell the fuel optimizer that I have 120 gallon tanks? Gonna try to start using that more instead of just fueling wherever I find it convenient to, figure it might save me some money if it really works.
  3. moosc
    moosc Road Train Member
    3,284
    1,172
    Mar 5, 2009
    Lincolnton NC
    It's no different then company. After u except load u tell it how much full u have. The only thing different is you'll be running longer between stops. But no way to physically tell it how big your tanks are. I know on company trucks, there replacing the fuel sender with a digital one that gives more accurate readings
  4. mickeyrat
    mickeyrat Road Train Member
    7,859
    7,542
    Nov 24, 2011
    on my 30 min break
    contact your IC DBL to see i fthey can get it changed specific to your truck. I run a day cab , single 100 gal tank. Last monday I was supposed to fuel twice. Once to start the day at 50 gal and second to end the day at 155 gal. Ummmm.........
    Spoke to my DBL today and she said they reset all trucks to 200 gal in the system for this new optimizer garbage. PITA if you ask me.
  5. gentleroger
    gentleroger Road Train Member
    7,973
    21,843
    Jun 1, 2010
    The change with the "digital switch" is that they're using the fuel economy off the performance monitoring. We still tell them how full or mt our tanks are.
    IMO the fuel 'optimizer' is a joke. I know we pay a different price than the posted price, and there are IFTA considereations, but half the time the solutions are asinine for efficient running of the truck. Going from MSP to Maxton, NC it gave me one fuel stop - LaSalle, IL. Ignore for the minute that LaSalle isn't enroute, but 850 miles is a little far to go on one tank.
  6. dieselfuelonly
    2,475
    5,086
    Nov 12, 2012
    Chapel Hill, NC
    BTW with those new fuel sensors... is it a easy plug and play type deal with the sensor? I wonder if they would work on my truck or of its something specific to Schneiders setups with the DD15s. My gauge set is very different from the company trucks. I'd like to have a more accurate reading from the sensors usually my dash gauge is way off, and I don't have a sensor that reads gallons burned either.
    I usually run anywhere from 1000-1100 miles on each fillup, I figure at the rock bottom figure of 6 MPG that gives me 1440 miles till bone dry, and of course the pickup is never gonna pull ALL the fuel from the bottom of the tank so I leave a little headroom.
  7. moosc
    3,284
    1,172
    Mar 5, 2009
    Lincolnton NC
    Just remember the tanks are curved at the bottom. If you get really low and climb a hill your fuel moves away from pick up. You also get trash when your fuel gets really low.
  8. gentleroger
    7,973
    21,843
    Jun 1, 2010
    I think the sensor is OEM. You might have one allready. Check you QC under system, then VDS and then poke around a little. There may be a digital fuel reading.
    When I had my glider I had a similar issue, a highly variable fuel gauage and no fuel burned reading. I just watched my real mpg, miles from last fill up and did the math. Usually was pretty close.
  9. dieselfuelonly
    2,475
    5,086
    Nov 12, 2012
    Chapel Hill, NC
    Yeah, I'd just like to have it working for those "can I really make it 100 more miles to the OC before stopping to fuel and not suck trash" situations lol. Next time I'm at an OC I'll ask the mechs about what all is involved and if its a plug and play type deal with a new sensor.
  10. moosc
    3,284
    1,172
    Mar 5, 2009
    Lincolnton NC
    Depends on your year. 14 and newer already equipped with new sending units. Older trucks are being retrofitted at there next pm. DFO next time your in Charlotte talk to the shop they'll b able to tell you which pieces are retrofitted.
    dieselfuelonly Thanks this.
  11. dieselfuelonly
    2,475
    5,086
    Nov 12, 2012
    Chapel Hill, NC
