Fuel pressure low
Discussion in 'Ask An Owner Operator' started by Jonnangharhary, Jun 18, 2021.
  1. Jonnangharhary
    Jonnangharhary Bobtail Member
    6
    Jun 18, 2021
    Hi guys,
    I have a Cummins ISX 2012 I having low fuel pressure sensor code. It stalls on low RPM but it is good on highway Alain it stalls on up hill when heavy, I changed following things but it did not fix the fuel pressure sensor, changed fuel regulator solenoid,
    I changed fuel rail pressure relive valve, changed one of the injector and ECM but still Sam issue any Idea what needs to be looked into.
    77fib77 Thanks this.
  3. snowwy
    snowwy Road Train Member
    20,612
    13,333
    Jul 6, 2009
    Fuel filters. Fuel pump.
    How many miles?
    Midwest Trucker and beastr123 Thank this.
  4. Spyro2112
    Spyro2112 Medium Load Member
    623
    433
    Mar 17, 2018
    Injectors, fuel pump is electronic. Works or dont
  5. mudflap77
    mudflap77 Heavy Load Member
    864
    1,314
    Oct 11, 2010
    South western Ontario
    High pressure pump is not electronic.
    These Pumps are well know to cause issues.
    If it is the pump coming apart you have probably screwed engine if it is so bad that it is stalling.
    Magoo1968 and jamespmack Thank this.
  6. AModelCat
    164,670
    Was this one of those ISX engines with the ceramic fuel pump plungers? If it is I'd look at that before the engine becomes a literal boat anchor.
    shooter19802003 Thanks this.
  7. Midwest Trucker
    5,914
    21,388
    Aug 31, 2018
    Maybe you have a clogged fuel filter? Maybe the fuel lines are going bad?
    drivinhome Thanks this.
  8. snowwy
    20,612
    13,333
    Jul 6, 2009
    How long do those things last?
    I don't know the specific on the engine but I'm driving a 12 t800 with isx now.
    And what do you know about the oil leaks? This block has the same da-- leak in the exact same spot the 05 w900 had i drove 12 years ago. Warped timing cover.
  9. mudflap77
    864
    1,314
    Oct 11, 2010
    A lot of the pumps with ceramic pistons detonated between 400 and 500,000miles.
    Even the upgraded steel pistons should be replaced by 600 000. It's much better to rebuild the pumps then waiting for a failure. They have a habit of wiping out the entire engine.
    The isx 2250 all came from factory with the ceramic pistons. Apparently some of the early 2350's randomly ended up with the old ceramic pumps.
    drivinhome and snowwy Thank this.
  10. Jonnangharhary
    6
    Jun 18, 2021
    It has 780 k in mileage but it has been overhaul at 747.
  11. Jonnangharhary
    6
    Jun 18, 2021
    I have not gotten the injector checked out but the mechanic said they are responding and the fuel pump is new it only has about 33k miles on it and you could clearly hear the sound of it when u turn the key on before turning it on.
