Fuel Prices are NOT the Problem
Discussion in 'Ask An Owner Operator' started by 7mouths2feed, Mar 12, 2008.
  1. bullhaulerswife
    bullhaulerswife Forum Leader/Admin Staff Member Administrator
    28,682
    46,280
    Jul 23, 2007
    Midwest
    This is good to hear. Is there a link to the local site? I'm sure that the story is there as well.
  3. Truckerjo
    Truckerjo Road Train Member
    2,314
    341
    Sep 5, 2006
    Indiana
    Here is the link to the site
    http://fox59.trb.com/
    They don't have anything posted on the Fox at 10 (on the left) link as of yet.. And the video that they have "Gas prices" is not the report they just ran.. So, may have to look a little...
    I will keep looking for it...
  4. Truckerjo
    2,314
    341
    Sep 5, 2006
    Indiana
    Wow that was fast... I emailed them and they said the entire report will be posted after the news cast... Hope that helps
  5. bullhaulerswife
    28,682
    46,280
    Jul 23, 2007
    Midwest
    VERY COOL!! Thanks!
  6. 7mouths2feed
    7mouths2feed "Family Man"
    1,186
    464
    Nov 29, 2007
    Jacksonville, AR
    One more of my "dumb" ideas!:biggrin_25522:
    Large companies get discounted fuel that they provide to leased o/o's at ?what?? $1.25- $1.50/gl??? Right??? What about something like a national discount fuel depots for O/O's? You have to submit some form of proof ??copy of registration to join and recieve a fuel charge card. Discount fuel purchases like the big guys. Might be able to get government assistance to get it up and running????? No emplyees except the re-fueler. No frills Just pumps. Thoughts????
    yeh I had a dream about it. look at the post time.
    Maybe it was a nightmare:biggrin_25523: Hmmm post time must be pacific. I think its nearly 2 am
  7. Eskimo6804
    Eskimo6804 Heavy Load Member
    816
    3,344
    Jun 13, 2007
    Northeast Alabama
    Labor unions is a bad comparison. That is collective bargaining. What you are talking about(multiple business owners uniting to charge whatever they want and all charge the same amount for their goods or services) is called collusion and is definitely illegal.
    If you are suggesting that the government re-regulate the industry, then that is different('cuz the govt.can do whatever the hell they want). We as individuals CANNOT unite in such a way or we will end up in FEDERAL prison.
  8. Working Class Patriot
    Working Class Patriot Road Train Member
    12,683
    23,165
    Jan 17, 2008
    Wherever and Whenever...
    If we charge in a Price Range than that would by definition not be collusion. In other words, you run at $1.75 pm, O/O Joe runs at $1.65 pm and I run at $1.70 pm or anywhere where in between, below, or above within say $.15
    True collusion would be every one runs at one price.
    http://en.wikipedia.org/wiki/Collusion#Characteristics
    So by running at a range:
    • We are not using a uniform price
    • Discounts are what we can run at in relation to our individual break even points
    • If the customer is included in price negations there are no "advanced notice" between carriers and the information exchange is through agreement between shippers and carriers.
    The thing is we all know what it takes to run our own break even points. So some might be able to run at $1.70 while others must run above $2.00. In my current case as a O/O in the dump biz, I can't run below $75 per hour with my ten wheeler and at that rate I need to work 20 hours a week to hit my base at of $1500 per work. At $80 per hour I need to work 18.75 hours not much of a difference but, when the low-rates kick in at say $50 per hour that means I would have to work 30 hours a week to hit the baseline. In the dump biz 30 hours is a rarity where 18-20 hours is doable and about average. Now factor that in with fuel cost on a dump truck which gets worse mpg than a otr rig say 4.5 -5 mpg if you're lucky.
    For instance today I ran 7 trips to the landfill which was only 2 miles away to the scales, 1 mile up to the dump area 1 mile back to the gate and 2 miles back to the job. My last load was a to a solid waste landfill about 6 miles away. So a 104 miles total for today at 8 hours x $82 per hour (-5% to the broker) $656.00 and after broker fees $623.20-$200.00 fuel (I should have burned 20.8 gals of fuel but that's a road miles at 5 mpg estimate. Going up the grade at the dump actually burned up a lot more fuel around 50 gals) = $423.20 TTT for today. Now imagine that same run at $50 an hour x 8 hrs which =$400.00 under those same conditions:
    $400.00 gross-5% ($20) $380.00- the $200 for fuel =$180.00
    Makes you wonder why anyone would run so cheap to cut everyone else out who runs at a fair rate.
    When things run the way they should I only need to run three days x $80 per hour x 8 hrs. or 4 days x $80 per hour x 6hrs. to make a decent gross ($1920) which is doable yet the low rates would have to run 5 days x 8 hrs. or 6 days x 6 hrs. to make that same gross and dumps even in good years, average 3 days a week.
    I still can't figure out how or why anyone would want to run cheap.
  9. Eskimo6804
    816
    3,344
    Jun 13, 2007
    Northeast Alabama
    What you are saying is the way the current system works. If you were to set up a price range as you say, it wouldn't be long at all before the bottom feeders were running at steep "discounts" to cut the rates so that they could gain larger market share.
    Without large amounts of corruption(threats,bribes,etc..) to keep people from discounting, a "price range" system wouldn't work. The bottom end of the range would just keep falling.
    Believe it or not, I'm NOT trying to be negative. I'mjust pointing out flaws that I see in some of the ideas that have been presented. I don't have an alternative solution, and quite frankly, I have no need nor desire to develop one. I am personally doing better than ever financially. It is unfortunate that not too many people could say that, but that is business. Only the strong will survive.
  10. 7mouths2feed
    1,186
    464
    Nov 29, 2007
    Jacksonville, AR
    Eskimo I don't believe anyone will feel like you are trying to be negative. The conversation between you and Ron are exactly what is needed. One has an idea and then discuss the why's and why not's the idea will work or not. You both have hit more closely to home what I was trying to suggest with my original post. You 2 have now refined it into a discusion of a price range. Which is what I was trying to suggest. This is precisely how a reasonable fix will come to be.
    Everyone has a Break Even Point(BPE) for thier business.
    Brickman has a truck payment around $650/wk while MedicinMan has no payment at all. Brickman may require a $7,500/yr= $.xx pm repair fund and MM requires a $20,000/yr= $.XX pm repair fund due to his older but paid for truck that breaks-down every 312miles. :biggrin_25522::biggrin_2559:
    Once all fixed expenses are figured they would balance out relatively close in their needs for a BPE.
    Brick Payment 650x52/120000=$ .28pm
    Repair fund $7500/120000 =$ .06pm
    $ .34pm required
    MM Payment $0
    Repair fund $20,000/120000=$16.6pm
    For a difference of $.174pm
    Both hauling flats all other things would be close to equal.
    Every driver is going to be different although most exspenses are relatively equal. Ins. ifta,irp,scales, food, clothes, hopefully showers :)...... flats all need binders and straps etc.
    Before you cut my throat I am using general numbers and I am not trying to nitpick about he has a dry box but I have to buy chains, straps and binders for my skateboard..
    I am speaking of skates to skates, reefer to reefer true BPE's would give a relatively close range for each driver.
    If 90% of drivers would NEVER haul for less than thier own BPE then rates would have to match. Yes there's the 10% idiot factor but how long can they stay in business with dumb business practices?
    I can already see that someone is going to bring up driver wages. This is a personal matter and each driver must give a resposible thought to what thier actaul NEEDS are, which does not nessicarily include that $35,000 Bass boat and New F-350 sitting at home.
    In the example of Brick and MM, Brick would resovle himself to driving his '98 Buick till his big rig is paid off while MM rides around in his fancy new jeep.:biggrin_25522:
    Unfortunatly many people over extend themselves when things are good and live beyond thier means only to start crying when things slow down. Trust me I see it every year with Noobs in the motorcycle industry. Summertime is booming so they go get a new bike, car, 60" flat panel and then October they are crying about not making enoung money to live on.
    Obviously I am speaking of general numbers, not specifics. Hopefully you will get my meaning and carry this thought forward with more (well thought out and helpful) discussions.
  11. MedicineMan
    MedicineMan Road Train Member
    5,799
    6,440
    Jan 13, 2007
    Woodville, TX
    HEY!! leave me out of this..
    I'll have you know I drove my truck 900 miles home and it only broke down twice. That's 450 miles between breakdowns! :biggrin_2552:
    And both my jeeps are paid for! lol
