Fuel recycle return line valve
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Drow88, Aug 29, 2018.
  1. Drow88
    Drow88 Bobtail Member
    11
    Seem to be getting air in fuel system. Changed lines from primary fuel filter to new transfer pump and back to tank as well . Left the recycle return line valve shut off and truck seems to run better..can I leave it off? 3406e caterpillar '04 -379.
  3. REALITY098765
    REALITY098765 Road Train Member
    1,520
    1,350
    Sep 17, 2017
    NO. You are probably overfueling the engine. Makes more power but could wash down the cylinder walls.
    Drow88 Thanks this.
  4. Drow88
    11
    Ok thanks. .hunting this down has been something. .loss of power,excessive exaust emissions. .
  5. Lepton1
    Lepton1 Road Train Member
    12,647
    25,589
    Nov 23, 2012
    Yukon, OK
  6. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    What engine do you have exactly.
    04 pete and 3406E dont go together
  7. Drow88
    11
    Yes it does MBN bridge motor c15
  8. swaan
    2,942
    4,374
    Jul 12, 2009
    BC canada
    Do not shut the return off.
    You will run the risk of blowing your O rings on the injectors from too much fuel pressure.
    Drow88 Thanks this.
  9. Drow88
    11
    Turned it back to on position..thanx
  10. swaan
    2,942
    4,374
    Jul 12, 2009
    BC canada
    Then it's not a 3406E like you said. It's a c-15 . There is a diffrence and trying to diagnose something when you got the right info is half the battle.
    Now then, tell us how you figure you have air in your fuel?
    Goodysnap Thanks this.
