fuel (Schneider)
Discussion in 'Schneider' started by luvcabover, Feb 17, 2018.
  1. luvcabover
    luvcabover Bobtail Member
    Can anyone tell me where Schneider drivers are allowed to buy fuel.
  3. driverdriver
    driverdriver Road Train Member
    4,254
    5,284
    May 30, 2011
    Mostly pfj. Sometimes the fuel solutions will include loves.
    Its not were they let you, it's were they tell you to.
    D.Tibbitt, Rollr4872 and luvcabover Thank this.
  4. Opus
    132,834
    If you're in a bind, you can get it wherever they sell it. Lots cheeper than a road call.
  5. Asphalt Anarchy
    Asphalt Anarchy Light Load Member
    93
    67
    Dec 4, 2014
    Atlanta, Ga
    They get the best price at PFJ but you can use your card at Loves and TA no problem. Some divisions your bonus is tied to where you fuel.
  6. gentleroger
    gentleroger Road Train Member
    7,952
    21,775
    Jun 1, 2010
    EFS card works at any PFJ, any Loves, amd any Kwik Trip.
    Select other locations will work as well (see driver resource guide).
    If none of the above is available you can call in to get the card turned on for a one time fueling any place that accepts efs.
    Everyload youll be asked for your fuel level. The "dispatch" in Navigo will then update with where Schneider would like you to fuel. Up to three times after that you can request a new fuel solution in Workflow.
    You need to follow the fuel solution 85% of the time. Putting in any amount of fuel counts as a fueling, same for def. Skipping stops doesn't count agaisnt you.
    Rollr4872, 91B20H8 and Opus Thank this.
  7. Echo5Mike
    Echo5Mike Bobtail Member
    Where can one obtain this resource guide online?
  8. gentleroger
    7,952
    21,775
    Jun 1, 2010
    They have stopped printing them, so Navigo is the only place to look up authorized fuel locations.
    If your fuel solution (listed under dispatch) is impossible, go to "where to", then "points of interest", "trucking", "fuel stops"
  9. rickybobby
    rickybobby Road Train Member
    4,843
    6,672
    Jul 10, 2010
    greensboro, nc
