Fuel Solenoid shut off wont work
Discussion in 'International Forum' started by Bradley8381, Feb 14, 2017.
  1. Bradley8381
    Bradley8381 Bobtail Member
    Hello, I'm trying to replace my fuel shut off solenoid on my 1996 international 4700. I have 3 wires, 2 have continuity to ground and one has 12.6volts. i hooked it up off a schematic I found online and it worked for a few minutes then started getting hot. I don't know if I should have 2 wires with power or just the one. If you can help that would be awesome. Thank you
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,551
    6,641
    Aug 26, 2014
    Wire 1: ground
    Wire 2: 12V when key is on
    Wire 3: 12V when starter is engauged
    There are two windings in the solenoid. 2 does not draw much current but has enough power to hold the plunger in. 3 draws a lot of current and is strong enough to pull the plunger in, then 2 holds it. If 3 has power all the time it will burn up in a short period of time.
    Heavyd Thanks this.
