Fuel tank hole..HELP
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by CDL CPL, Sep 26, 2019.
  1. CDL CPL
    CDL CPL Light Load Member
    186
    63
    Aug 14, 2017
    Iowa
    So we hit a board in Memphis and got a puncture hole in the main fuel tank. Is there anyway to close that tank off and just use the secondary tank?
    We got the family and are just trying to get home. What can we do to temporarily fix this problem?? Please any help is much appreciated!!
  3. loudtom
    loudtom Road Train Member
    1,717
    2,805
    Aug 26, 2016
    When I removed my secondary tank, I threaded a bolt into the end of the lines and hose clamped it. You'll have to manually keep track of your fuel levels, though, since it usually is determined by the sensor in the primary tank. I think there were 2 lines, a return and supply. The vent hose on top is for air only, so you shouldn't have to detach it.
  4. Hulld
    Hulld Road Train Member
    2,884
    6,567
    Oct 19, 2015
    Upstate NY
    How big is the hole?
    Can it be temporarily plugged?
    A picture might help to see what you got.
  5. BoxCarKidd
    BoxCarKidd Road Train Member
    4,525
    6,586
    Aug 26, 2014
    What are you driving? How do the lines hook up to each tank?
  6. CDL CPL
    186
    63
    Aug 14, 2017
    Iowa
    IDK how to add a picture at the moment. I still got fuel spilling everywhere.
    It's a hike in the bottom of the main tank. Keeping track of fuel level is no problem. How can we cut off the main tank or is that even possible?
  7. BoxCarKidd
    4,525
    6,586
    Aug 26, 2014
    Sometimes a dime or a nickle will fit in between the end of the hose and the tank fitting. Tighten the fitting up good to plug it off. Both hoses have to be done.
    CDL CPL, pushbroom and Cattleman84 Thank this.
  8. Cattleman84
    Cattleman84 Road Train Member
    9,996
    71,336
    Nov 1, 2017
    The Sticks, Idaho
    Some trucks have valves on the tanks to prevent fuel pump from pumping from the tank with the closed valve... However it will still return to both... So it would still leak...
    Got a big wad of Bubblicious Bubble Gum???? Lol
    Intothesunset and BoxCarKidd Thank this.
  9. Cattleman84
    9,996
    71,336
    Nov 1, 2017
    The Sticks, Idaho
    Yes thus would work good... Like you say, both supply and return lines could be plugged this way.
  10. CDL CPL
    186
    63
    Aug 14, 2017
    Iowa
    End of which hose and tank fitting?
  11. BoxCarKidd
    4,525
    6,586
    Aug 26, 2014
    Some IHC's use an electric pump to transfer fuel. What is a main tank?
