Fuel tank hole..HELP
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by CDL CPL, Sep 26, 2019.
  1. Cattleman84
    Cattleman84 Road Train Member
    10,026
    71,608
    Nov 1, 2017
    The Sticks, Idaho
    Both the supply hose... AND the return hose. They will probably be hoses at least as big as your finger.
    CDL CPL and BoxCarKidd Thank this.
  3. CDL CPL
    CDL CPL Light Load Member
    186
    63
    Aug 14, 2017
    Iowa
    So we
    So we got both hoses on the main tank plugged off.. still leaking what's in the main tank of course but is that gonna be ok to drive? Is it going to only use the 2nd tank or how's that work?
  4. CDL CPL
    186
    63
    Aug 14, 2017
    Iowa
    I just need to get it to stop long enough to dry jb weld it or use some flexi seal or some #### to seal the leak
  5. CDL CPL
    186
    63
    Aug 14, 2017
    Iowa
    2013 Freightliner cascadia
  6. loudtom
    loudtom Road Train Member
    1,717
    2,806
    Aug 26, 2016
    It should be ok, like get you from point A to point B. But probably not ok to cross the scales with until you stop the leaking entirely.
    Make sure you clean it really good before putting JB weld or epoxy on it, or it might have trouble sticking.
    CDL CPL Thanks this.
  7. BoxCarKidd
    BoxCarKidd Road Train Member
    4,551
    6,641
    Aug 26, 2014
    Will only use fuel from the tank without the plugged lines. You could leave the large line hooked up and it will transfer fuel to the other tank because there is only return fuel to the other tank. That takes a while. If you run it untel that tank runs dry the engine will shut off.
    Being as it is a very small leak you need to contain it. Only drive to a safe isolated spot and handle the situation safely. You do not want to polute the world or have fuel cause an accident.
    Marine puddy in a tube you kneed together might work but best to just transferr fuel to other tank.
  8. Cattleman84
    10,026
    71,608
    Nov 1, 2017
    The Sticks, Idaho
    If you got the correct hoses plugged, then the fuel pump will only draw off the other tank, and only return to the other tank... BUT ONLY IF YOU GOT THE CORRECT HOSES PLUGGED.
  9. CDL CPL
    186
    63
    Aug 14, 2017
    Iowa
    There are 2 black hoses and 1 blue hose (which goes to the other tank)
    We got the 2 black hoses plugged. Are these the right hoses? I don't think there is anymore on there.. Is it ok to drive like that?
  10. Cattleman84
    10,026
    71,608
    Nov 1, 2017
    The Sticks, Idaho
    Sounds right... The blue hose should be plugged on one end as well if all it does is connect the 2 tanks... If it is left open fuel from BOTH TANKS will be leaking out of the hole in the main tank..
  11. CDL CPL
    186
    63
    Aug 14, 2017
    Iowa
    If we plug the blue hose how will it get any fuel from that second tank? That's the only hose on that tank
    The truck is off at the moment so it shouldn't be sucking fuel from anywhere
