Fuel tank not equivalent. Can anyone help?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Cascadia2015, May 27, 2019.
  1. Cascadia2015
    Cascadia2015 Bobtail Member
    I got a 2015 Cascadia Auto DD13. My truck only use the passenger side fuel tank while driving idling. The fuel from the passenger tank goes to the driver tank. When I Stop and turn engine off the tank will level off and the two tank will equivalent. I replace the vent valve that didn't work. I remove the the heat fuel pump on the tank and stick a hanger in there to try to poke any that might stuck that didn't work. TA and a local diesel shop said I need to clean the tank because something stuck in there. It cost $1000 to do it and they not sure it work. I drive about 150 miles or so to stop for fuel and for the tank to be equivalent because I worry I run out of fuel. Can anyone help?
  3. sirjeff
    sirjeff Medium Load Member
    Did you replace BOTH vent valves? (Assuming 1 for each tank..... dont have a freightliner but each tank on my vulva has it's own breather filter)
    If you crack the caps and run like that for a while, will they equalize?
  4. LDLWells
    LDLWells Heavy Load Member
    782
    1,219
    Jan 14, 2019
    If you are running and you go to pull the caps off are either of the tanks under a vacuum?
  5. Smellfunny
    Smellfunny Road Train Member
    1,446
    967
    Jan 28, 2012
    South Carolina
    I have found that if the tanks are venting properly and one tank is staying full or gaining fuel while the other goes down that the tank with the abundance of fuel has a blockage on the suction side of that tank. I would get fuel tank low and suck out as much fuel as possible then with cap off remove the suction line on that tank and blow back into it. I have found anything from oil caps, panty hose, tire thumpers straps, plastic food wrappers in them. Sometimes it is difficult to find the item.
    Newto Trucking and LDLWells Thank this.
  6. LDLWells
    782
    1,219
    Jan 14, 2019
    Are Freightliner tanks like Peterbilt with those metal pipes that go to the bottom of the tank?
  7. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    F/liners have the fuel tube starting at top and stop at a few in. from bott. and both return lines run to equal valve that is mounted on rear of trans and when you have one tank full and other near empty, ck for blockage then replace the Equaliser valve while its fuel lines are off blow everything you can into a bucket under truck ck. for plastic bags and other things that can block off fuel?
