In the past I have always slightly bent the new unit to go into the fuel tank. Can't do that with this new sender, I need to spin the tank. The tank is empty, one band loose. The other band won't budge. As you all know there is very little room to get a long wrench on the nut. Sooo how do you guys get the straps loose on a Pete? Don' want to cut it.
fuel tank sending unit
Discussion in 'Peterbilt Forum' started by mtoo, Jan 1, 2015.
Have you disconnected the leveling valve rod and used the air bags to raise the cab/sleeper as high as they can go?
mtoo Thanks this. -
Thought of that, haven't tried it yet.
Well this sucks, peterbilt gave me the wrong sender. My old one has a female pigtail coming off the unit, the new one has a male plug directly on the top of the unit. You would think after giving peterbilt the serial #, you would get something as simple as a sending unit right.
That New Years Day project is over. Next project rebuild the air dryer, new cartridge - purge valve and heater. Hope those parts are right. Miss the old AD-9 dryer, not sure I like the AD-IS -
Dont forget the lube on alum. threads before screwing new filter on dryer so next time it will unscrew?
mtoo Thanks this. -
That sending unit replaced the older one. They sell a jumper harness to connect the new sender to the old harness. PN# P92-7180-0650 it's around $14. Just went through this for 26" tank.
Changing the pigtail must have been a Paccar bright idea. The same scenario exists on a KW. Fortunately my parts guy knew I would need a pigtail.
I just returned the senders. It was just going to be a New Years Day project and didn't need to be done. The only reason I was doing it was because the right tank doesn't read full, but works from 3/4 on down. Stuff like that bugs me, but no real reason to change them.
