Fuel tank showing empty but it’s more than half full.
Discussion in 'Kenworth Forum' started by Haula**, Apr 15, 2020.
  1. Haula**
    Haula** Bobtail Member
    23
    35
    Jun 15, 2018
    Issue with my fuel tanks and gauge.
    it shows empty then when I go to fuel.....the left tank is empty and the right tank is completely full......
  3. Haula**
    23
    35
    Jun 15, 2018
    2015 W900 by the way
  4. p608
    p608 Road Train Member
    2,181
    2,993
    Nov 10, 2016
    Problem is somewhere in the crossover line
    Haula** Thanks this.
  5. Haula**
    23
    35
    Jun 15, 2018
    Thanks. I’ll take it on in.
  6. 48Packard
    48Packard Ol' Two-stop Shag!
    8,516
    10,530
    Apr 19, 2009
    Could be anywhere
    Back in about 1999 I was assigned a brand new Volvo 660. I fueled at the yard and drive to Knoxville from Nashville. It was nighttime. Got to our drop yard in Knoxville and went to bed. Woke up to the sound of the engine dying and a small river of fuel running from my tractor.
    Turns out the dealer hadn’t opened the above mentioned crossover line, causing fuel to escape out the vent in the cap. Entire side of the trailer was covered in diesel. When my company checked other newly arrived units, they found several others with the same issue.
  7. Lyle H
    Lyle H Road Train Member
    1,292
    2,947
    Apr 16, 2014
    They haven't used crossover lines in years.
    It's more than likely a clogged vent or a clogged or broken pickup tube.
    If this is a new problem that's where I would start. I can only estimate that the OP has had this truck for a while and it's a new problem.
    If he does happen to have shutoff valves for each tank on both the feed and return line, check to make sure they are both open.
    Roberts450 Thanks this.
  8. Lyle H
    1,292
    2,947
    Apr 16, 2014
    Let me clarify that. By crossover line I mean the line that used to go under the tank from each side. There are lines on the topside that go to a splitter valve. That sometimes can be the problem too.
    Also, if you have shutoff valves make sure they are both open.
    48Packard Thanks this.
  9. p608
    2,181
    2,993
    Nov 10, 2016
    Yeah a crossover
