Fuel tanks inside cleaning
Discussion in 'Volvo Forum' started by dorlia2, Dec 17, 2021.
  1. dorlia2
    dorlia2 Light Load Member
    149
    28
    Apr 20, 2012
    DOWNERS GROVE
    Aren’t those plugs meant to be used to drain debries from bottom? My concern is if they can leak later
  3. Snailexpress
    2,675
    6,069
    Apr 28, 2014
    Rocky
    Yes, they are to drain tanks. Yes it;s big chance they will leak because it's really hard to put plug back with fuel running along your arm and didn't damage plug threads. To open plugs you need to have very low fuel level in the tank. The lowest level you can achieve is about 10 gal. To drain 1 gallon of debris you will drain 5 to 8 gallons of fuel. As i said diesel shower guarantee. I did it, believe me. The easiest and cleanest way it's to take the sludge with siphon or pump Pamela posted.
    BennysPennys and Pamela1990 Thank this.
  4. Dino soar
    Dino soar Road Train Member
    4,809
    26,922
    Dec 8, 2017
    They won't leak but it's best if you drain the tanks.
    When you reinstall them you can put plumbers thread sealant on them. You do not have to make them crazy tight either.
    They are pipe thread but they are special fuel tank tapered threads designed not to leak. I still put the plumber's putty on mine just to be safe, although with that type of a thread you don't really need to.
    This is the sealant that I use even for airline fittings and whatever. Occasionally I use teflon, but almost always I use this.
    https://www.homedepot.com/p/Hercules-Real-Tuff-4-oz-Pipe-Thread-Sealant-156152/203304169
    Pamela1990 Thanks this.
  5. Pamela1990
    Pamela1990 Road Train Member
    1,820
    10,719
    Nov 7, 2021
    B.C. Canada
    I park on a hill so the low spot is the back of the tanks, let the truck sit there a few hours. Then put the siphon tube in the lowest part and suck out a few gallons from each tank.
    I do it yearly.
    BennysPennys Thanks this.
  6. JoeyJunk
    JoeyJunk Road Train Member
    8,762
    68,030
    Dec 31, 2010
    Washington, PA
    Even ones bowels?
  7. jason6541
    jason6541 Road Train Member
    2,425
    5,366
    Mar 5, 2012
    Omaha, NE
    You volunteering to be the Guinea pig?.
    try it out and get back to us.
    In all seriousness, got to watch it someone will
    Think it a great idea and try it. Then yet another warning label to protect the idiots among us who have no common sense.
    Snailexpress Thanks this.
