Fuel tanks over flowing
Discussion in 'Ask An Owner Operator' started by Perchie15, Aug 17, 2021.
  1. Perchie15
    Perchie15 Light Load Member
    253
    75
    Aug 16, 2021
    Have a DD15 that has only been sucking fuel out of drivers side tank and the passenger side has been over flowing but when u take the caps off over night they both equalize pretty quick. Even when driving down the road have the lids off slightly it will equalize down the road. have changed both vents! Not sure what else to look at!
  3. Big Road Skateboard
    7,172
    40,619
    May 2, 2021
    Either not sucking from right tank, or it's not returning fuel to the left.
    Has the tranny been out recently?
  4. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    Follow both fuel lines from fuel tanks to back of trans. and look for where they all conn. together to the part that allows fuel to stay at a even level in both tanks, that's what you need to buy and replace.
  5. trucknguy
    trucknguy Medium Load Member
    698
    1,825
    Mar 19, 2015
    West coast
    Blocked vent in the cap
    feldsforever, Tb0n3, 77fib77 and 4 others Thank this.
  6. danny23tx
    danny23tx Road Train Member
    1,494
    2,324
    Feb 16, 2016
    Austin,Tx
    Happened to me to , never fixed it lol . Tanks slowly equalize sometimes , my apu socks fuel from passenger tank so I just top it off now and than . I replaced one vent and cleaned the other , the other day it was definitely pulling some from passenger side idk I just keep rolling.
    NavigatorWife and Rideandrepair Thank this.
  7. TJB15
    TJB15 Light Load Member
    67
    115
    Apr 29, 2020
    If fuel line is sucking air or draw tube is cracked it most likely would suck air and die or at least lose prime sitting for extended period. I would check to see if there is a splitter valve in return line also check for anything floating in tank that can get sucked up against draw tube or for obstruction in draw tube. (maybe remove line and purge tube with air) also sometimes old lines will collapse within themselves. Just some random thoughts from my experiences. Definitely might be more things I have no clue about.
  8. Perchie15
    253
    75
    Aug 16, 2021
    Like I said I replaced both vents but these fuel caps don’t vent. Says right on the cap itself
  9. Perchie15
    253
    75
    Aug 16, 2021
    yeah they connect to top of the trans like 2 3way fittings by looks of it forsure one 3way fitting I haven’t got a close look at them yet likely a T fitting looks like all I need to?
    Rideandrepair Thanks this.
  10. Perchie15
    253
    75
    Aug 16, 2021
    If one tank is draining completely? And other was is filling up? Likely be it
    Definitely doesn’t die cuz the fuel light has come on.... well it probably will if he never opened up the caps slightly.
  11. Rideandrepair
    17,574
    56,926
    Aug 8, 2015
