Fuel toggle on 386
Discussion in 'Peterbilt Forum' started by 1988DRU, Oct 5, 2013.
  1. 1988DRU
    1988DRU Bobtail Member
    Feb 8, 2008
    Calgary, AB
    Just picked up a 2008 386 with a cummins ISX. Noticed this fuel toggle on the dash and can't figure out what it is. The guys at the dealership didn't know either....any thoughts?
  3. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    r tank, L tank gauge
    Ezrider_48501 and 1988DRU Thank this.
  4. Ezrider_48501
    3,845
    5,130
    Apr 2, 2011
    bismarck, nd
    baha is correct R-L fuel gauge one nice feature you see quite a bit on pete's and rarely ever any other trucks, not something your use often but its nice in a case were you might notice your fuel gauge rising or dropping faster than it should you can check to see that your tanks are pulling equally and a suction line plugged or something causing it to pump all your fuel to one side or the other.
    of course one truck i drove the right tank always read 1/4 tank less than the left tank even though they were in fact even.
    1988DRU and g.o.a.l Thank this.
  5. 1988DRU
    Feb 8, 2008
    Calgary, AB
    Thanks for the replies - makes sense now why when I played with it it didn't appear to do anything. Any idea which is which (up for right side, down for left)?
    baha Thanks this.
  6. baha
    4,137
    2,837
    Jul 25, 2013
    ga
    next time U fuel start one 1st leave key on ck. on level after 30gal.
  7. bubbanbrenda
    bubbanbrenda Road Train Member
    1,388
    650
    Feb 27, 2011
    Middletown,Oh.
    Pop off the fancy chrome ring and see if its labeled under there
  8. Gliderpilot
    Gliderpilot Bobtail Member
    32
    4
    Jun 13, 2013
    New Jersey
    up is right tank down is left tank
  9. Flying Dutchman
    Flying Dutchman Road Train Member
    1,274
    522
    Nov 2, 2009
    Northern California
    Peterbilt had these on our trucks up until 2004, nothing for 2005-08, then showed up again in our new 2014 trucks.....a monitor for each tank. We have 70 gallons on the driver side and 50 on the other. My right/passenger side gauge is the only one that works. When I flip the switch to the driver side tank it reads full all day long.
