Fuel water separator issue??
Discussion in 'Questions From New Drivers' started by Birkkman, Jan 22, 2025.
  1. Birkkman
    Birkkman Bobtail Member
    4
    Dec 16, 2024
    (2019 freightliner cascadia) So when the truck is off and sitting the fuel water separator is about halfway full or so. When the truck is running the filter fills up. Not overflowing or anything. Just full. Wondering if this is normal or is it an issue with the fuel lines or anything else?
  3. Espressolane
    18,812
    118,133
    When was the last time the filer was changed?
    Also have an engine mounted fuel filter, when was that one changed?
  4. Davyjoneslocker
    Davyjoneslocker Bobtail Member
    10
    4
    Jan 14, 2025
    I would change the filter first and see what happens. If that doesn’t work, probably change the whole thing.
    77fib77 Thanks this.
  5. 77fib77
    77fib77 Road Train Member
    11,763
    77,971
    Jul 7, 2010
    St Louis
    It could be restriction on the engine mounted filter. That's a $40 filter. Change it up and fill it up and put it on without spilling any ....... They re-prime. And see if it works.
    The davco drain off the bottom and check for water. I'm almost certain you won't have any.
