Fuel water separator
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Kenllah, Aug 23, 2018.
  1. A5¢
    A5¢ Medium Load Member
    389
    544
    Oct 30, 2017
    I looked around on the internet and I think the company is no longer around. It seems to be a "use it until it gets plugged up and replace the whole thing" filter and parts are hard to find.
    eBay had an old listing and it sold for over $200! You may be best off replacing it, like you were thinking. How long have you had the truck?
    spsauerland, SAR and Goodysnap Thank this.
  3. Kenllah
    Kenllah Light Load Member
    226
    113
    Nov 17, 2017
  4. A5¢
    389
    544
    Oct 30, 2017
    That is all the information I could find. Sorry I couldn't help you out.
  5. Kenllah
    226
    113
    Nov 17, 2017
    That's ok. I'll get a different one
  6. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    I'd take that thing off and just use a normal spin on water separator.
  7. Kenllah
    226
    113
    Nov 17, 2017
  8. Kenllah
    226
    113
    Nov 17, 2017
    Got it ordered napa. If you are in the same boat, this is what I got. SmartSelect_20180824-144829_CM Browser.jpg SmartSelect_20180824-144811_Gallery.jpg
  9. swaan
    2,942
    4,374
    Jul 12, 2009
    BC canada
  10. Rideandrepair
    17,566
    56,910
    Aug 8, 2015
    I had one on 92 Western Star.Drain is useless as it’s always plugged. Plastic bowl prone to breakage. Supposed to loosen top first and drain. Never seemed to work right just stirred up sentiment. It only separates doesnt filter. I’ve been using a fleetguard fs1000 great fuel filter/seperator w/drain which I never use just make sure it’s tight.Look it up the filter has a great flow rate even when almost full of water.
  11. Kenllah
    226
    113
    Nov 17, 2017
    Thx. Got her done already $76 napa. Although any filter with a one inch hole by 14 threads will spin on the housing. A problem I had been having was enging would start fine and run for about 10 seconds then would die. Crank long enough to reprime and would fire up. Well when I took the lines off the old separator, there was no fuel coming out the supply side. There was a leak on the old one somewhere. Problem is now solved. 20180828_181920.jpg
    AModelCat and Rideandrepair Thank this.
