Fuel will not equalize when driving
Discussion in 'Volvo Forum' started by BlackThought, Feb 2, 2018.
  1. BlackThought
    BlackThought Medium Load Member
    566
    463
    Jul 22, 2014
    Memphis,TN
    Getting very frustrating. I fill up, and drive 6-700 miles. Guage shows I'm at 1/4 tank by the time I'm close to stopping. Rest for the night and fuel shows half a tank. Drive more and it drops quick as if the fuel is going to my secondary but not coming back.
    Ive measured with a stick and it is indeed very uneven.. Almost ran out of gas once, with a quarter tank in my second.
    09 670, what so I need to fix to get this working right?
  3. BobbyD13
    BobbyD13 Bobtail Member
    25
    14
    Feb 10, 2017
    There is vents on top of your tanks, usually they have i little lose running down the tanks on the outside. I would check and clean/replace those before i do anything else. Is they are dirty it will cause vacuum in the tanks.
    easytopleez33, flood and BlackThought Thank this.
  4. BlackThought
    566
    463
    Jul 22, 2014
    Memphis,TN
    Checked those a while back. Hoses weren't blocked. The brass piece wasn't gummed up or anything
  5. Frontman
    Frontman Light Load Member
    166
    151
    Apr 4, 2012
    Sure sounds like a dirty dober done clogged one of the vent lines off the top of fuel tank.
  6. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    On a 2004 t600 and my current 2015 t 680 I run into the same issue .. after changing numerous parts on the t600 I figured out its temperature related and just dump a bottle of conditioner in tanks .. it solves the issue for a month or two and I repeat the process .. I think it's moisture related .. You may want to try this first before going through the parts changing procedure
  7. sirjeff
    sirjeff Medium Load Member
    There should be a little canister type filter at the end of each of the breather tubes 20$ or so. Change em both or pull em off and see if your tanks equalize.
    My lines were clear however I found if there wasnt equal restriction between the 2 filters, it would throw it all out of wack
  8. BlackThought
    566
    463
    Jul 22, 2014
    Memphis,TN
    Do you have a pic?
    Mine has a brass fitting with a ball inside. When I took it off the ball moved freely. Thought it was fine. There is nothing at the bottom of the tube. Unless you're talking about the brass thing.
  9. sirjeff
    I'l try to take a pic tomorrow. Mine is a '14 (Im assuming it's the same)
    The breather hose should run from that brass fitting, down around the tank and into a little white plastic filter (the size of a mini pop can, shielded with a bent piece of tin held by 2 or 4 little bolts) on the lower inside of one of the tank straps
  10. BlackThought
    566
    463
    Jul 22, 2014
    Memphis,TN
    Read a similar topic and someone suggested that maybe it's the chain from the fuel cap. The main tank lid doesn't have a chain on it anymore. Idk if it's in the tank or not. Got the truck used.
  11. BlackThought
    566
    463
    Jul 22, 2014
    Memphis,TN
    Would a rotated tank cause a level issue?
    My main tain the fuel lid is at 12oclock the problem tank the fuel cap is in between 3 and 4 o clock
    Would this cause the problem?
    Need replies asap before I spend a hundred bucks
