Fuel
Discussion in 'Freightliner Forum' started by Tonyb229able, Nov 28, 2013.
  1. Tonyb229able
    Tonyb229able Bobtail Member
    15
    I have a 2010 freightliner Columbia. How many miles should I get on both tanks being full. And how far can I get when it just starts showing on empty? Cause I no when it shows empty I have went 50 miles. Just didn't no how far I could go.
  3. Balakov100
    Balakov100 Road Train Member
    3,938
    2,641
    May 10, 2012
    Temple, TX
    What kind of question is that?
    You should be able to get 200 miles easily.
    Tonyb229able Thanks this.
  4. Tonyb229able
    15
    Lol. We'll I had a 1998 fld. And that truck went 140 miles and ran out. This is newer truck and didn't no if is was better or worse on that part. But thanks for your answer
  5. passingthru69
    Depends on your fuel gauge. Some times the float will drop showing mty and you still have maybe 20 gallons you can use.
    Some fuel gauges are not real actruite. Best thing to do is when it shows a 1/4 tank go get fuel.
    Try not pushing your luck. Also weight of the load and roads, like pulling hills or winds will drop it in a hurry..
  6. Balakov100
    3,938
    2,641
    May 10, 2012
    Temple, TX
    You didn't give enough info for a better answe.
    How big are your Tanks and what's the EXACT Fuel mileage.
    Pen/Paper MPG. (there are Smart Phone Apps that willddo it for you also )
    Not ECM or Qualcomm or People net mpg.
    Me personally I don't like letting it get very low.
  7. 25(2)+2
    18,762
    46,074
    Sep 18, 2006
    the road less travelled
    The ones on the Cascadia work real well, and it even has a light that comes on a 1/8 to 3/16ths.
    It depends on how big the tanks are(how much fuel you start with), and how many miles per gallon, which can vary some.
    A bar that will reach the bottom of the tank, through the filler opening, can be used to check, and also to make sure the Equi-flo is working right, making sure the tanks are even when running and parked on the level.
    2 identical Columbias, mine would go 300 miles on empty, the other never would have gotten to MT. I learned to look into the tanks for awhile when running a different truck.
  8. Tonyb229able
    15
    Thanks guys. They are twin 100 gallons tanks. And as far as fuel mileage goes it differs. Depending on my load. Around 7.5 to 8 mpg.
  9. BigSam
    BigSam Light Load Member
    220
    241
    Mar 23, 2008
    Illinois
    80% of tank capacity is usually the most the tanks will hold. Thus 160 gallons max.in your case. I myself don't trust the fuel gauge enough to let it get less than a 1/4 tank before filling up.
  10. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    driving in winter time, you will never know when you might be sitting on road for many days at any time, best to keep tanks as full as poss.
  11. Ezrider_48501
    3,845
    5,135
    Apr 2, 2011
    bismarck, nd
    i often can go 1000 miles on a fuel up, i don't let the gauge get below 1/8th of a tank though normally fill at 1/4
