Full load, grades, no engine brake
Discussion in 'Questions From New Drivers' started by J Man, Feb 3, 2013.
  1. pattyj
    pattyj Road Train Member
    22,474
    20,138
    Jul 19, 2008
    Sioux City,ia
    I use to use them as much as you but going thru many twns that have a noise ordanance broke me of the habit because I have drove trks with real loud jakes.
    darthanubis Thanks this.
  3. losttrucker
    losttrucker Road Train Member
    1,436
    1,041
    Mar 9, 2008
    greenville,nc
    You got told you were wrong, proved you were wrong but still stand behind your statement of
    and
    So according to you another way of descending a grade is to RIDE the brake all the way to the bottom of the hill and WHEN, not if, but WHEN it catches fire just keep riding...................
    Anyone with an IQ above 5 knows if you take 2 objects and PRESS them together while one is moving; due to something called FRICTION it will build heat and it will continue to build heat until the objects are no longer touching.
  4. snowman01
    snowman01 Road Train Member
    1,246
    713
    Sep 27, 2011
    North Carolina
    A number of o/o use the trolley to burn up the company trailer brakes and save the brakes on their trucks which the o/o have to pay to replace.
    darthanubis and Chinatown Thank this.
  5. thelushlarry
    thelushlarry Road Train Member
    3,023
    9,003
    Jan 9, 2012
    glasgow ky
    If you do want to smoke the brakes push the clutch in!!!!!!!!
  6. Eaton18
    Eaton18 Road Train Member
    1,755
    1,104
    Sep 3, 2011
    Waverly, KS
    :biggrin_2559:, and when the truck gets going waaaay toooo fast, unbuckle the seatbelt, open the door, yell "BONZIE" and jump out...:biggrin_2559::biggrin_2559:
    daf105paccar, pattyj and Chinatown Thank this.
  7. losttrucker
    1,436
    1,041
    Mar 9, 2008
    greenville,nc
    Test them, help me slow down, either way it applies the brakes! When Im running 70mph and enter a 55mph zone; yep I use it to slow me down!!
    You use it for dumping and I use it to slow me down a couple MPH!! Would I try to go down a mountain using just that?? NEVER!! However, like I said, coming to a reduced speed area such as a town or construction zone, Yep I do use it!!
    Eaton18 Thanks this.
  8. Chinatown
    Chinatown Road Train Member
    79,364
    193,008
    Aug 28, 2011
    Henderson, NV & Orient
    InstructionsMountain Driving
    Apply light, steady pressure to the brake pedal so you do not overheat the brakes. Overheated brakes can result in melted air lines and a complete loss of air brakes. Avoid a hard application of the brakes. A stable breaking procedure will work better and reduce the likelihood of overheating the brakes. Driving down a mountain in a big truck can be extremely dangerous and should only be attempted by an experienced driver or with a certified instructor in the truck supervising.
    As I said, there's more than one way to skin a cat. Sometimes there's more than one correct answer.
    Just like it states "loss of air brakes", not spring brakes, it's reading comphrension.
  9. pattyj
    22,474
    20,138
    Jul 19, 2008
    Sioux City,ia
    lmaooooooooooooooo:biggrin_2559::biggrin_2559::biggrin_2559:
  10. pattyj
    22,474
    20,138
    Jul 19, 2008
    Sioux City,ia
    Ray and I will be teaming this Spring,he's driving all the mountains,lol.
  11. snowman01
    1,246
    713
    Sep 27, 2011
    North Carolina
    Yeah, and that is why post #4 disqualifies everything you say. You just answered yourself.
    Chinatown and losttrucker Thank this.
