Full load, grades, no engine brake
Discussion in 'Questions From New Drivers' started by J Man, Feb 3, 2013.
  1. d o g
    d o g Trucker Forum STAFF Staff Member
    24,732
    54,352
    Sep 20, 2010
    Texas
    You guys try to discuss this issue without exchanging insults, please. Thanks.
    snowman01, Eaton18, DedHedEd and 7 others Thank this.
  3. daf105paccar
    6,564
    7,294
    Apr 15, 2012
    No grade is too long to start out slow.
    In fact with no engine brake starting SLOW is the ONLY way to do it.
    To any newbee/wanabee remember this all your life:
    YOU CAN GO TO SLOW AS MANY TIMES AS YOU LIKE
    YOU WILL ONLY GO TO FAST ONCE!!
    To anyone faced with a similiar situation i would suggest they read this very good.
    It has the best advice.
    credit to Losttrucker for posting this
    [FONT=&quot]1 .
    [/FONT]
    [FONT=&quot]- [/FONT][FONT=&quot]Proper Braking Technique[/FONT]
    [FONT=&quot]Remember.
    [/FONT]
    [FONT=&quot]The use of brakes on a long and/or[/FONT]
    [FONT=&quot]steep downgrade is only a supplement to the
    braking effect of the engine. Once the vehicle is in
    the proper low gear, the following are the proper
    braking techniques:
    Apply the brakes just hard enough to feel a definite
    slowdown.
    When your speed has been reduced to
    approximately five mph below your "safe" speed,
    release the brakes. (This brake application should
    last for about three seconds.)
    When your speed has increased to your "safe"
    speed, repeat steps 1 and 2.
    For example, if your "safe" speed is 40 mph, you
    would not apply the brakes until your speed
    reaches 40 mph. You now apply the brakes hard
    enough to gradually reduce your speed to 35 mph
    and then release the brakes. Repeat this as often
    as necessary until you have reached the end of the
    downgrade[/FONT]
    As to the things Chinatown has posted,
    i respectfully have to disagree with him.:yes2557:
    Long ago i used to drive a 6 axle truck trailer combo grossing over 130 000lbs without an enginebrake and had i driven like Chinatown suggested i would have burned my brakes and crashed many times.(or maybe just crashed once and died)
    In fact a another driver tried it that way and burned all the brakes on his trailer.(even the grease in the bearing got melted out off the bearings)
    What Chinatown doesn't realise is that his way ,at best the brakepads get "glaced".
    Which means they become rockhard and lose most off their stopping power.
    Now i don't want get involved in a fight with Chinatown and if he feels happy with his way ,that is his right.
    I just don't agree with him.:biggrin_25513:
    tnpete, darthanubis, allniter and 2 others Thank this.
  4. Tonythetruckerdude
    Tonythetruckerdude Crusty Deer Slayer
    2,909
    54,694
    Dec 8, 2012
    hunting...../ retired
    Best rule of thumb is too start down the hill in the same gear or maybe 1 gear lower than you used to climb the hill, depending on the percentage of the grade, your weight, AND the condition of the brakes on your truck. Some trucks used to have what they called an application gauge, this let you know just how much air was being used to apply the brakes...haven't seen one in many years though, I'm guessing when jakes became less expensive and the technology got better there was no more need for that kind of gauge. IMO, the best way..... is start down in the correct gear, use steady EVEN pressure to let both your engine and brakes hold the truck speed down don't let the thing start to gain too much speed, then there is no need to stab/fan the brakes. IMO, stabbing wastes precious air pressure and causes the brakes to heat-up much faster than a steady even foot on the brake. It worked for me for over 3 decades...but to each his own.
    darthanubis, 7-UP and Chinatown Thank this.
  5. Chinatown
    Chinatown Road Train Member
    77,953
    185,453
    Aug 28, 2011
    Henderson, NV & Orient
    You explained it better than I did. Only had brakes flame twice in my career, and it lasted maybe a minute or less, then went out.
  6. MNdriver
    MNdriver Road Train Member
    7,985
    4,372
    Feb 24, 2012
    Both methods work, both methods were taught years ago.
    My trainer, when I started years ago, required me to do both proficiently before he'd let me out of the truck.
    IMO, the idjits in the mountains aren't the ones coming down the grades at the posted truck speed limit, it's the ones that feel they can fly down them faster than a car.
    Can you go down them that fast? yop, but you are forgetting one rule of physics.....
    Never drive faster than your brakes.
    darthanubis, magoo68 and NavigatorWife Thank this.
  7. tracyq144
    tracyq144 Heavy Load Member
    884
    546
    Feb 15, 2009
    MN
    Exactly. No jakes in my first two or three trucks, and I scared myself a couple of times on both I-80 and I-70.
    darthanubis Thanks this.
  8. okiedokie
    okiedokie Road Train Member
    14,022
    111,527
    Jun 13, 2011
    PNWET
    I ran Triples(105 GVW)off the Cascades in OR w/ out Jakes. Used a gear that would hold me back w/ about 5 psi application. It worked for me. Knowing the hill makes all the difference.
    darthanubis, DedHedEd and 7-UP Thank this.
  9. old timer123
    old timer123 Light Load Member
    54
    27
    Jan 29, 2013
    Villa Ridge,Mo.
    hell of a trk driver!!! lol tell em like it was yrs ago and stop thier crying driver.they dont know how to go down a little mountain hill without jakes they dont need to be in a truck.10-4
    DedHedEd and Chinatown Thank this.
  10. Ezrider_48501
    3,845
    5,135
    Apr 2, 2011
    bismarck, nd
    you just gotta open the door jump out run along side it and drag your feet
    'olhand and Eaton18 Thank this.
  11. J Man
    J Man Medium Load Member
    306
    197
    Dec 31, 2011
    Middle of nowhere
    sorry I think I gave you the wrong impression, on short hills I start out slow, brake some, gain a gear and rest the brakes, brake some and gain another gear, etc. but these hills are too long for that. as for stab braking as soon as I let up on brakes the truck gains so much speed that I have to brake harder than I want to start losing those extra 5 mph and that really heats those brakes up.
    Chinatown Thanks this.
