Full load, grades, no engine brake
Discussion in 'Questions From New Drivers' started by J Man, Feb 3, 2013.
  1. okiedokie
    okiedokie Road Train Member
    14,017
    111,484
    Jun 13, 2011
    PNWET
    Thread hi-jack. Your driving off road ,the truck HAS a jake and your loaded. So you have to come down this 25% grade. What do you do?
  3. MNdriver
    MNdriver Road Train Member
    7,985
    4,372
    Feb 24, 2012
    25%?
    stop. You aren't going to make it. you cross over the drop and you'll hang up your landing gear. Not to mention, your 5th wheel doesn't have that much travel in it to flex.
    darthanubis and okiedokie Thank this.
  4. J Man
    J Man Medium Load Member
    306
    197
    Dec 31, 2011
    Middle of nowhere
    I drove it last in a 6spd auto, and 2nd in that one is faster, so in the 18 I must be remembering wrong, gonna try her out in 2nd and should have better results. many thanks.
  5. Eaton18
    Eaton18 Road Train Member
    1,755
    1,104
    Sep 3, 2011
    Waverly, KS
    1. Stop truck set parking brake.
    2. Call for helicopter to lower my rig down.
    I'm going to correct my previous answer, as it is Snub braking I was thinking of, not Stab. Anyhow brake to slow 5mph from max safe speed.
    darthanubis and losttrucker Thank this.
  6. snowman01
    snowman01 Road Train Member
    1,246
    713
    Sep 27, 2011
    North Carolina
    step out of the door and pull the ripcord.
    darthanubis, Eaton18 and Hammer166 Thank this.
  7. snowman01
    1,246
    713
    Sep 27, 2011
    North Carolina
    why, exactly, are you driving off of a road? Drilling rig?
  8. okiedokie
    14,017
    111,484
    Jun 13, 2011
    PNWET
    Most off road trailers do not have landing gears and the ones that do(Floats)are folded back. The Dozer hand trims the crest off so you can drop off to the main grade. Logging,Pipelines and Oil Patches/Drill Rigs have these kinds of driving conditions.
  9. rbrtwbstr
    rbrtwbstr Road Train Member
    3,402
    7,948
    Jul 11, 2012
    in the bush somewhere
    it sounds to me like you are actually in too low of a gear, and trying to snub brake.....in a lower gear, your rpms will climb quicker. While I would agree snub braking is the better way to go, if you are in too low of a gear, you will find yourself hitting the brakes more often to keep from over-revving the engine, which will bleed air pressure, causing loss of brakes. my suggestion is this....pick a higher gear, maybe instead of second, try third or fourth. use the snub braking idea. If you do it correctly, it should take 5 seconds to slow down from your safe speed, and you will be able to descend hills all day long. And while I normally disagree with losttrucker, he is very right on this...
    darthanubis and DedHedEd Thank this.
  10. losttrucker
    losttrucker Road Train Member
    1,436
    1,041
    Mar 9, 2008
    greenville,nc
    I also stand corrrected: It is Snub Braking to slow 5mph from max safe speed.
    darthanubis Thanks this.
  11. KMac
    KMac Road Train Member
    3,427
    3,067
    Jan 26, 2012
    Waxahachie, TX
    Stevens trucks all have jakes... Drivers are taught to descend mountains with and with out the jake... never know when it may fail.
