Fuse blowing
Discussion in 'Ask An Owner Operator' started by Thotphobia, Oct 31, 2022.
  1. Thotphobia
    Thotphobia Light Load Member
    69
    47
    Apr 21, 2021
    Hey guys, I was wondering if any of you guys ever had a problem like this, my fuse for the gauge lights keep going out, and even when I try to put a new fuse in, it blows out before I even try to stick it in. I checked behind the dash, I changed the ignition and still nothing. Any help would be appreciated!
  3. shatteredsquare
    shatteredsquare Road Train Member
    1,407
    1,841
    May 23, 2014
    middle dirt
    use a bigger fuse until it stops blowing then follow the smoke to the fault location
    lester Thanks this.
  4. Inderjit
    Inderjit Heavy Load Member
    771
    737
    Sep 17, 2017
    what make of truck and what year?
  5. Thotphobia
    69
    47
    Apr 21, 2021
    Everything works, turn signals, emergencies headlights, exterior lights, just the gauges are the bad ones
  6. Thotphobia
    69
    47
    Apr 21, 2021
    1990 peterbilt 379
  7. shatteredsquare
    1,407
    1,841
    May 23, 2014
    middle dirt
    if you have a dash mounted dimmer switch for the gauge cluster check the dimmer switch and its housing for corrosion and condensation, there are tabs or something on the side of the switches you can pop the box out and pop out the individual switches to inspect/clean/replace
    Rideandrepair and tscottme Thank this.
  8. D.Tibbitt
    157,284
    Is it your gauge lights? Or your actual gauges not working? You probably have a wire rubbed thru, grounding out on a piece of metal behind the dash
  9. shatteredsquare
    1,407
    1,841
    May 23, 2014
    middle dirt
    jfc it probably needs a new stack of D cells
    Rideandrepair Thanks this.
  10. tscottme
    tscottme Road Train Member
    You have a short-circuit. If you put in a big enough fuse to not blow you will be buying a new wiring harness or truck after the fire dept is finished with their work. The short-circuit could be caused by an almost broken wire, a pinched wire, a screw driving into wires somewhere.
    RJM1953, D.Tibbitt and Rideandrepair Thank this.
  11. Rideandrepair
    17,572
    56,924
    Aug 8, 2015
    Look for brittle or broken wires, melted plug at switches. Might get lucky and find something. Dome lights shorting out and causing fires was a problem on early 90’s Pete’s.
    D.Tibbitt, RJM1953 and Diesel Dave Thank this.
