Fuse blows in fuse box???
Discussion in 'CB Radio Forum' started by Boneyard6867, Oct 31, 2017.
  1. Boneyard6867
    Boneyard6867 Bobtail Member
    6
    I just got in a 2016 Prostar, tried to hook up my CB radio but every time I connect it the fuse in the fuse box pops not the inline. There are two wires, green and white. I determined with my tester that the green is hot and the white is not. I don’t even get a chance to turn the thing on before it blows. I’ve tried this with and without antennas. Don’t understand this. Thanks!
  3. rabbiporkchop
    9,678
    6,548
    Feb 9, 2012
    Wapwallopen, Pa
    Measure ohms from power lead to ground lead. If zero ohms, radio is shorted.
  4. Boneyard6867
    6
    Thanks for reply but I don’t have an ohms meter. Thought about doing a quick connect to battery just to see if it is a bad radio? Any thoughts on that? Thanks again.
  5. rabbiporkchop
    9,678
    6,548
    Feb 9, 2012
    Wapwallopen, Pa
    Good idea
  6. Jazz1
    Jazz1 Road Train Member
    2,373
    4,971
    May 7, 2012
    Thunder Bay On
    Are you using correct size fuse? I tried a 3 amp in my radio,,blew right away. Requires 10amp
  7. Jace379
    Jace379 Light Load Member
    146
    97
    Mar 6, 2017
    Find another ground.
  8. Boneyard6867
    6
    Well it has an inline fuse that uses the old glass fuses, guess I could replace it with the mini fuse?
  9. Dirtymartini15x
    Dirtymartini15x Light Load Member
    180
    114
    Oct 18, 2016
    What radio are you trying to use? If it's a larger export radio or a radio with an rfx kit chances are the fuse/wiring in the truck isn't sufficient to handle the amp load.
  10. ShooterK2
    ShooterK2 Road Train Member
    5,533
    89,470
    Dec 14, 2012
    Oklahoma
    He said it pops the fuse as soon as he connects the radio to power. No matter how big a radio is, the receive only draws a small amount of power. Now, if it were popping the fuse when he keys up, that's a different story. But this radio has a problem somewhere. He needs to use a multimeter and ohm the pos/neg as suggested. A cheap multimeter can be had for less than $10.
    Jazz1 Thanks this.
  11. Dirtymartini15x
    180
    114
    Oct 18, 2016
    I didn't read it the way he intended I guess.
