1. jimjam38
    jimjam38 Medium Load Member
    399
    54
    Nov 6, 2011
    chickasha, oklahoma
    Maybe someone here knows. I am in this 2019 Cascadia. In the bunk I have three 12v outlets. One is up by the climate control and light switches. The other two are in front of the bunk. The two on the bunk, I had my koolatron "fridge" and a little 300w inverter plugged in. No issues until this morning. I get up, neither is working. I pulled the cover off the fuse panel and every fuse that it said 12v I pulled and checked. No burnt out ones. Lifted bunk and the rear of the sockets looks fine, no sign of melting and they weren't heated up. Did I pull every fuse, but the correct one? When it gets serviced, the techs at the shop could probably trace it to the source, but I have no idea when my work will get me through. I just usually wait until they call me, but I know it hasn't been quite three months since the last one.
    Trucking Jobs in 30 seconds
  3. Hatt91
    Hatt91 Bobtail Member
    40
    58
    May 18, 2018
    Maybe your battery voltage dropped too low and shut off power to the accessory outlets?
    Truckin joe81 and tscottme Thank this.
  4. tscottme
    tscottme Road Train Member
    6,180
    9,317
    Jul 25, 2008
    Nashville, TN
    I think you are right. I have a 2018 Cascadia. Those 12v outlets are shut down when the truck batteries get low. I have an APU. If I forget to arm the APU those 12v outlets get shut off. If I arm the APU those 12v outlets get shut off for a second and then the APU fires up and the outlets are live again.
    The 12v outlets near the dash don't shut down
  5. jimjam38
    399
    54
    Nov 6, 2011
    chickasha, oklahoma
    Mine doesn't have an APU. I usually idle it up and let it run at night while I sleep. I can check the voltage when I get back in it. Sitting in a shop getting trailer worked on. Never thought about the battery, since I only shut the truck off when I go home.
  6. jimjam38
    399
    54
    Nov 6, 2011
    chickasha, oklahoma
    Well, my truck is showing it is pulling 14.2V Still nothing when I plug into either socket.
  7. MPBara
    MPBara Bobtail Member
    6
    7
    Nov 4, 2017
    Maybe check your inverter in the truck.. It may have tripped it breaker
    Truckin joe81 Thanks this.
  8. jimjam38
    399
    54
    Nov 6, 2011
    chickasha, oklahoma
    I have a 1500w inverter installed but I only use it for microwave and tv. Eventually, I was going to get a little dorm fridge and ditch the koolatron. I just used the plugs for the little inverter and the koolatron. The main inverter is still working fine showing what the truck shows 14.2v pull
  • Draft saved Draft deleted
