Galaxy 33hp problem
Discussion in 'CB Radio Forum' started by bcaudill, Feb 19, 2017.
  1. bcaudill
    bcaudill Bobtail Member
    My radio has started lately going low on recieve signal. People talking will be low unless really close. I can key the mic and it will come back for a few minutes, then will notice it has gotten quiet again. This will happen even in area with alot of cb traffic. Is this what's known as channel drift or what would cause this? Thanks
  3. Bout Z
    Bout Z Light Load Member
    275
    1,149
    Mar 14, 2015
    so. ohio
    Sounds like a cold solder joint. Very common on these radios, and can be a pita to find when the problem is intermittent.
    If you can solder, a good place to start is the 10.24 crystal, the vco area of the board, and tuning cans.
    Or find a competent tech..which can be just as big a pita from what I understand...
  4. BTShepp
    BTShepp Blue Demon
    373
    215
    Oct 31, 2015
    Chicago, IL
    Unfortunately, these Galaxies seem to be having lots of problems.
    Diesel Dave and bcaudill Thank this.
  5. CW Spook
    CW Spook Light Load Member
    Could also be a dirty T/R relay, but that will probably also take a good tech to fix.
    bcaudill Thanks this.
  6. Turbo-T
    Turbo-T Road Train Member
    1,953
    708
    May 31, 2009
    I second the cold solder joint. I had a Galaxy 929 that would receive and transmit one minute and then not the next. When it quit, you could push on the board toward the back with the eraser end of a pencil and it would come back to life.
    bcaudill and Diesel Dave Thank this.
  7. Diesel Dave
    9,794
    33,871
    Jan 20, 2010
    Hesperia, Ca.
    Times two. It happened to my Galaxy and it took the second Tech to find it. Chris Holland at CB Radio Store in Ontario Ca. found the broken solder to be more exact.
    rabbiporkchop and bcaudill Thank this.
