looking at this radio, $205.00 is this about right for what they are doing?
or is there a better radio I should be looking at?
This is Effingham radio
WE ARE OPEN AND AVAILABLE 7 DAYS A WEEK NOT INCLUDING NATIONAL HOLIDAYS
WE USE B&K OSCILLOSCOPES, B&K 2040 SIGNAL GENERATORS AND B&K 1040 CB SERVICE MASTERS
ALL OR OUR CUSTOMER’S RADIOS ARE FIRST OPENED AND INSPECTED FOR FACTORY DEFECTS, COLD SOLDER JOINTS, BROKEN CONNECTIONS AND MANUFACTURERS DEFECTS.
EACH RADIO IS THEN PUT THRU A RIGOROUS 27 STEP ALIGNMENT, PER THE GALAXY DX 959 SSB SERVICE MANUAL, FOR UNMATCHED PRO TUNED & ALIGNED PERFORMANCE,
SPECIFIC FACTORY RECOMMENDED PLL ALIGNMENTS ARE PERFORMED!
TRANSMIT STAGES ARE OPTIMIZED FOR LOUD AND CLEAR OUTPUT AUDIO ALONG WITH CRYSTAL CLEAR MODULATION!
FACTORY GATE VOLTAGES ARE CHECKED, RECHECKED AND TUNED!
ALL INTERNAL FREQUENCIES WILL BE PROPERLY ALIGNED AND SET FOR BEST PERFORMANCE!
RECEIVER FUNCTIONS AND PERFORMANCE ARE TESTED, TUNED, AND SET FOR THE CLEAREST INCOMING SIGNALS POSSIBLE.
ALL METER FUNCTIONS ARE CHECKED AND ALIGNED
FINAL RADIO CHECK AND TESTS ARE PERFORMED USING A LIVE OPERATOR AND A REAL FUNCTIONING BASE ANTENNA SETUP.
JUST CHECK OUR FEEDBACK FOR OUR CUSTOMERS REACTIONS.
WE HAVE A EXCELLENT REPUTATION, TRACK RECORD AND FEEDBACK SCORE.
ALL RADIOS COME WITH 14 DAY NO HASSLE RETURN POLICY!!!
galaxy dx 959
Discussion in 'CB Radio Forum' started by slim shady, Oct 8, 2016.
Save your money.
$169 with free shipping
https://www.walmart.com/ip/Galaxy-D...39803&wl11=online&wl12=39900385&wl13=&veh=semslim6596 Thanks this. -
So out of the box is just as good ?
rabbiporkchop Thanks this. -
Stock will be much better
slim shady Thanks this. -
Do you ever like a radio that has been worked on? Or only stock?slim shady Thanks this.
Depends who worked on it.BTShepp Thanks this.
I wouldn't purchase anything from that guy that owns Hutton's CB shop at Exit 78 unless you can prove you didn't tamper with any adjustments inside the radiolilillill Thanks this.
I'll second that. He hacked the hell out of my 3300.rabbiporkchop Thanks this.
