Galaxy keeps popping fuses.
Discussion in 'CB Radio Forum' started by UpstateFreight, Nov 23, 2017.
  1. UpstateFreight
    UpstateFreight Light Load Member
    262
    139
    Mar 8, 2016
    Potsdam,Ny
    So I just got a new Galaxy Dx 979. It's peaked and tuned. Very nice radio I really like it... when it's not blowing fuses that is! :biggrin_25512:. Every time I switch it over to LSB or USB it blows the inline fuse in the power cord. It's only a 2amp fuse. I did buy some 10amp but idk if it will be ok to throw it in. I don't want to cook my radio. What amp fuse should I be using? Is a 10 ok, or should I just get a pack of 5 amp? :dontknow:
  3. NightWind
    NightWind Road Train Member
    2,718
    19,173
    Nov 11, 2006
    Sunny South, AL
    You need at least a 10 amp fuse. What are you wiring it to and have you read the manual?
    http://www.cbradio.nl/galaxy/Service_Manual_Galaxy_DX979_ENG.pdf
    UpstateFreight and Broke Down 69 Thank this.
  4. Kevin83165
    Kevin83165 Light Load Member
    144
    106
    Nov 24, 2011
    Herrin Illinois
    I use 5 amps in my DX 959 for the same exact reason. Every time I switched from SSB to AM or visa versa it would pop the 2 amp
    UpstateFreight Thanks this.
  5. UpstateFreight
    262
    139
    Mar 8, 2016
    Potsdam,Ny
    Just the standard wiring that is in my T680. And yes I did read the manual. It is only a few pages though. Nothing like the one you provided in the link
  6. UpstateFreight
    262
    139
    Mar 8, 2016
    Potsdam,Ny
    I have the pack of ten amp and I figure that would be plenty.
  7. NightWind
    2,718
    19,173
    Nov 11, 2006
    Sunny South, AL
    Where are you wiring it to? Make sure that has a fuse that will handle the radio.
  8. UpstateFreight
    262
    139
    Mar 8, 2016
    Potsdam,Ny
    Just the standard connections in a T680. I've never had a problem like this with inline fuses. Always had low powered radios though. Like a stock Uniden bearcat, and a Cobra 29
  9. delta5
    delta5 Road Train Member
    1,193
    7,404
    Sep 9, 2010
    Whom ever "tuned" it probably cranked the power up way too high...
    BTShepp and Diesel Dave Thank this.
  10. wolverine11
    wolverine11 Road Train Member
    1,628
    1,234
    Apr 1, 2015
    The Galaxy 949/959 is a single final Am 4 watt legal radio with the same power output as the Bearcat and Cobra 29 you referred to, and on ssb it is rated at 12watts and when on ssb the current drain is 4A max and that is why it is blowing 2.5A fuse when on ssb.
  11. Ridgeline
    22,730
    123,528
    Um ...
    Switching over side band blows a fuse ... right?
    Not transmitting but just switching when on receive ... right?
    BTShepp Thanks this.
