gallons per idle hour?
Discussion in 'Experienced Truckers' Advice' started by CaptainKirk, Apr 3, 2013.
  1. CaptainKirk
    CaptainKirk Light Load Member
    91
    20
    Dec 8, 2012
    Virginia
    I'm finding the general consensus at only 1 gal/idle hour. Seems low. Anyone have hard data?
    Chipperrr Thanks this.
  3. volvodriver01
    volvodriver01 Road Train Member
    Most of the time its actually less than 1 gallon per hour. No hard data other than I am the one that buys and pays for fuel. :biggrin_25525:
  4. rank
    rank Road Train Member
    9,919
    113,510
    Feb 11, 2010
    We used to have a driver that would stay at the Hook 30 miles from his house and idle over night because he said he didn't want to wake everyone up when he got home. His "thoughtfulness" cost ~$40/night.
    Chipperrr and 86scotty Thank this.
  5. 25(2)+2
    18,762
    46,044
    Sep 18, 2006
    the road less travelled
    It's around a gallon per hour at recommended idle RPMs, Volvo idles at a lower RPM so it would be somewhat less than that.
    The ISX was supposed to idle at 800, the DD15 at 900, n-14s were dropped back to 900 from 1100.
    Series 60 should have been 800 to 900 Not sure about Cats but slow idle wasn't recommended by most manufactures for long periods of time.
    In the Series 60s, low oil pressure took out the turbo bearings at slow idle. I'm thinking most other engines would have that same problem, along with other problems.
  6. Tonythetruckerdude
    Tonythetruckerdude Crusty Deer Slayer
    2,909
    54,861
    Dec 8, 2012
    hunting...../ retired
    Yep...any idle speed much lower than 1000rpm's does not keep enough oil moving to lubricate the turbo bearings.
    Chipperrr and chopper103in Thank this.
  7. me myself and I
    me myself and I Heavy Load Member
    736
    312
    Oct 5, 2009
    vernon hills,Il
    really?. Bearing on my N14 was still fine at 950k when I sold my old truck, I replaced turbo on ISX at 800k and not due to bearing going bad. And when I idle its 600 rpm. As far as fuel used display on my Volvo shows .5 g/h at low idle and .8 on high idle
  8. ironpony
    ironpony Road Train Member
    17,502
    12,015
    Sep 23, 2007
    Ask my GPS...
    So... figure on 0.8 g/h, a 10 hour break every day, and 51 weeks per year, 6 days per week... that's 2448 gallons of fuel every year. Take your own fuel price, but I'll use $4/gallon - that's $9792.00 per year - every year to idle. Kinda makes that APU look a little more affordable.
    Chipperrr, 86scotty, 88228822 and 2 others Thank this.
  9. Scatman435
    Scatman435 Bobtail Member
    10
    4
    Apr 4, 2013
    FL
    Ive only had ISXs. Dash readout went between .5 and .8 gph.
  10. me myself and I
    736
    312
    Oct 5, 2009
    vernon hills,Il
    Really? 10 hrs every day? Really
    As far as your numbers go its very convincing...except for one tiny thing. Correct me if I'm wrong, but I belive that diesel powered APU's use ( burn ) diesel. Number of .3 g/hr comes to mind. So using your high number of .8 g/hr you save .5g/hr. Its $ 2. Assuming 2000 hrs idled a year that's 4k savings. I don't know how much routine maintenance will run you but it got to be at least 500 a year. So you'll save about 3500 a year. Since new APU will run you north of 10k we talking 3 years till break even point. And that's without a penny for repairs. How likely is that?. So run that no brained part by me again, cause I don't get it.
    Chipperrr, ncmickey and Aamcotrans Thank this.
  11. Pound Puppy
    Pound Puppy Heavy Load Member
    974
    868
    May 31, 2010
    Amherst, OH
    It is also said that one hour of idle is equal too 100mi of driving. Ive heard this from many mechanics and on a lot of trucking radio. So other than paying for fuel you also have to change oil sooner and put un compensated wear on your engine.
    Cabinover101 Thanks this.
