Gas card procedure.
Discussion in 'Averitt' started by I.C. Weiner, Dec 30, 2017.
  1. I.C. Weiner
    I.C. Weiner Bobtail Member
    28
    40
    Nov 20, 2017
    Fellow Averitt Express drivers I've never had to use the card because I usually fill up at one of our facilities. I'm in need of a fill up now. I remember them telling me there was an extra step when using their gas card. Can someone describe the gas card procedure for me.
  3. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,094
    Mar 5, 2016
    White County, Arkansas
    Gasoline?
    There should be a company handbook inside your paperwork that they gave you at orientation. This is not the time to be running out of fuel.
    I.C. Weiner and CrappieJunkie Thank this.
  4. Nukem
    Nukem Road Train Member
    1,237
    1,447
    May 11, 2014
    you will need to send in a mac 14 and make sure you get the amount of fuel you want on the card. (I usually ask for 500.00) once they send a msg saying it's there, then go to the fuel island...
    slide your card... if at a pilot it will ask for your rewards card next.
    next, type in your unit number... truck number with the letter T in front. ( I.E. T14678)
    it'll ask for fuel type and if you want DEF
    then it asks for hub reading... (Mileage entered)
    once that's done... follow the rest of the steps (yes/no/skip) then fuel away
    you do not need to get the fuel receipt as it's electronic with the comdata card, so no need to go inside if you don't want to. If you want to, or your FM says to, then go for it.
    chopper103in and I.C. Weiner Thank this.
  5. I.C. Weiner
    28
    40
    Nov 20, 2017
    Thanks. I think this may have been my worst day as a driver to date. I started driving in late February so I didn't have any experience with driving in below freezing/snowy conditions.. Well due to my inexperience I went through 3 trailers today and spent my entire day broken down. Apparently you're not supposed to set your trailer brakes when it's cold out. I found out the hard way. I look at it as you can never learn if you don't mess up.
    chopper103in and IluvCATS Thank this.
  6. IluvCATS
    IluvCATS Road Train Member
    4,091
    8,971
    Dec 1, 2014
    Seattle, WA
    A lot of people don’t know about the trl brakes. Also know your tires can be hot if you park too fast after driving all day. Then those hot tires melt the ice underneath them. Which then refreezes lol
    I.C. Weiner and chopper103in Thank this.
  7. Nukem
    1,237
    1,447
    May 11, 2014
    I also forgot to mention that if your going to be shutting down at a place that is below freezing, you might want to get some anti gel as well, if you don't have any in the truck... you can get some from Averitt as well, but READ THE BOTTLE! the stuff they give you is enough for 300 gallons.
    While your at it... also get:
    - Spare set of wiper blades
    - Spare light bulb or 2
    - A gallon of oil and coolant (I keep 2 ea.)
    - Straps (Load locks just plain suck)
    If you have any questions please feel free to PM me.
  8. bamamac
    bamamac Medium Load Member
    671
    282
    Nov 4, 2010
    Alabaster,Alabama
    That is some very good advice
    That's good advise Nnkem.
    chopper103in Thanks this.
  9. chopper103in
    chopper103in Road Train Member
    2,407
    6,562
    Apr 11, 2010
    Crossville,Tn
    I'm glad I'm dedicated, none of that mac crap for fuel
    Texas_hwy_287 Thanks this.
  • Draft saved Draft deleted
