Gas in oil of pony motor on RGN? How is this happening?
Discussion in 'Heavy Haul Trucking Forum' started by Hegemeister, May 12, 2019.
  1. Tug Toy
    Tug Toy Road Train Member
    7,150
    74,884
    Jul 4, 2015
    Corn field
    Might check the overflow charcoal canaster. As you go down the road the fuel will slosh and run out the vent into the canaster and then into the air cleaner housing and THEN into the carb down Into the engine.
    That’s what happened to my generator. I pulled the overflow hose out of the charcoal canaster and no more problems.
  3. former mechanic
    former mechanic Bobtail Member
    May 13, 2019
    If this is truely a gasoline eng honda, does it have a gas return line that returns a small amount of gas to the tank while it is running to keep the gas (in the engine's mechanical fuel pump) from getting too hot and boiling and causing vapor lock like many cars had near the end of when they had carbs. It could be feeding back from it especially if the tank gets hot and builds excess pressure due to a not properly pressure relieving gas cap. They are typically a pres/vacuum relieving gas cap that lets air in the tank as fuel is used. Maybe a improper aftermarket (or unvented) gas cap that isn't relieving pres. Sometimes this excess tank pres. can overcome a manual gas shut-off valve and or the carb float valve. Or the manual shut off valve is leaking slowly.
    Hegemeister Thanks this.
  4. Hegemeister
    Hegemeister Road Train Member
    1,912
    1,660
    Jun 16, 2012
    Mechanicsburg, PA
    I was able to start the motor after a couple of days driving. Ran for a few seconds. Next day tried again and it would not fire at all. Looks like the fuel valve is working.
    So now when I shutdown. I'll starve at low RPM, then try cranking to confirm carb is fully drained.
    In the past. I shutdown at high RPM which may have left some fuel in the carb. Fingers crossed.
  5. m16ty
    m16ty Road Train Member
    2,274
    4,964
    Jan 22, 2016
    Stuck float in the carb, or leaking fuel pump, if it has one. Other than mistaking the oil fill for the fuel fill, that is the only way for fuel to get in the oil.
    Shut the fuel off after each use. That will keep this from happening again.
  6. fast1buzz
    fast1buzz Light Load Member
    93
    115
    Feb 6, 2019
    colorado
    If the problem persists after all else fails I had a Kohler pony motor on an older Trail King that after being rebuilt by a Kohler Repair dealer it was doing exact same thing. They had installed the new piston and rings with the top ring upside down. It would fill the oil completely full of gas while running. Even on a new engine this could possibly happen. I don't know how a person could tell but I would be talking with the dealer if you have tried every thing else.
  7. AModelCat
    166,498
    How long are you leaving the valve open before you start it? Wondering if the float is stuck and its trickling in before you start it?
    Oxbow Thanks this.
  8. Hegemeister
    1,912
    1,660
    Jun 16, 2012
    Mechanicsburg, PA
    Yeah, but if the float was stuck, I would think I'd have problems during normal operation.
  9. Hegemeister
    1,912
    1,660
    Jun 16, 2012
    Mechanicsburg, PA
    But if there's a problem with the ring, wouldn't you think it would more likely blow smoke? In my experience, ring problems burn oil.
  10. Heavy Hammer
    Heavy Hammer Road Train Member
    1,184
    5,890
    May 1, 2013
    In purgatory
    Sounds to me like your fuel shut off valve has become a fuel almost shut off valve, and over time the bowl fills, and naturally the bouncing around while going down the road causes fuel to leak into the cylinder, past the rings, and into the crank. Your needle/seat/float works properly though, because you haven't indicated pony run issues...
    Pull the bowl, by removing the center bolt, and see if there is any trickle of fuel while in the OFF position.
    cke, Oxbow and Hegemeister Thank this.
  11. Heavy Hammer
    1,184
    5,890
    May 1, 2013
    In purgatory
    Whatever the issue, I for one sure want to hear the final diagnosis of this issue.
    I'm a gearhead, so there's nothing that peeves me more than someone who lists an endless breakdown of issues, then NEVER posts the result/reason...
    Wait, maybe I'm a a Curious George?
    If you were closer, I'd rip that motor out, tear it apart, and figure this out before would be able to go to sleep.
    cke and Hegemeister Thank this.
