Gauge Problem. Heavyd...please help!
Discussion in 'International Forum' started by bwinters149, Aug 5, 2018.
  1. bwinters149
    bwinters149 Bobtail Member
    6
    1992 international 9400
    Speedo and Tach gauges will peg out when truck is started. Tach works properly but speedo does not work. There are two sets of wires coming from the speed sensor so I would assume the speedo reads directly off the sensor?
    HeavyD: I hope you read this because you could really help. Back in 2016 there was a thread where you uploaded a wiring diagram to help a guy with this same issue. I couldnt get the wiring diagram to download. Do you still have that? Thanks for the help.
  3. SAR
    SAR Road Train Member
    2,756
    36,654
    Nov 26, 2011
    ND
    I will tag him so he can help you.
    @Heavyd
  4. Heavyd
    Heavyd Road Train Member
    7,812
    6,265
    Feb 4, 2009
    Here it is again.
    SAR Thanks this.
  5. bwinters149
    6
    Can’t get it to download. Would you be able to email it to me? Email is (my truckers report profile name)@gmail.com
  6. Heavyd
    7,812
    6,265
    Feb 4, 2009
    I think it is because you are new member. Should work after you get a few more posts.
  7. bwinters149
    6
    Alright. Thanks!
  8. bwinters149
    6
    Alright. Thanks!
  9. Clocke2324
    Clocke2324 Bobtail Member
    Hi heavyd I have a 2001 9200i and my oil pressure light is on and i have replaced the oil sensor and plug and cluster panel and it still comes on i have checked with manual gauge by oil filter and it says I've got good oil pressure any ideas
  10. Heavyd
    7,812
    6,265
    Feb 4, 2009
    That gauge and warning light gets it's data from the engine ECM. I would be plugging into the engine and check for codes and see what the ECM is seeing for oil pressure. The side gauge panel is actually run and controlled by the center speedo/tach panel incase the cluster is faulty.
    SAR Thanks this.
