gear box
Discussion in 'Trucks [ Eighteen Wheelers ]' started by truckerbangin, Apr 8, 2013.
  1. truckerbangin
    truckerbangin Light Load Member
    268
    45
    Jan 22, 2013
    if i change out from a 10spd to a 13/15/18spd gear box will i have to recalibrate ecu on my ddec iv
  3. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,212
    Jan 7, 2013
    A few may have to be changed. You'll have to check the VSS parameters. If progressive shift is enabled, you'll have to check the gear ratios set in the limiters tab for that.
    The number of output shaft teeth will most likely be 16 on any trans you put in, but verify that. You'll have to program the top gear ratio and second highest gear ratio to match the new trans.
  4. mark mechanic
    mark mechanic Bobtail Member
    14
    Adelaide Australia
    agree with gapeape vss is required because you havent stated if it direct single or double o/d your looking to fit cheers mark
