Gear ratio for oil field work pulling tanker?
Discussion in 'Experienced Truckers' Advice' started by Thore, Oct 23, 2023.
  1. Thore
    Thore Bobtail Member
    44
    43
    Dec 9, 2014
    KC
    Im currently running a 389 pete, 18 spd, cat 6nz 550 hp with 3.25 rears. I run in the oilfield pulling a tanker. My weight is usually between 100k-120k on every load. I do pull some good hills and mts passes every now and then. Curious what your opinions are on my gear ratio?
    expedite_it Thanks this.
  3. bad-luck
    bad-luck Road Train Member
    3,440
    6,337
    Nov 16, 2013
    Baltimore, Maryland
    With that weight, and depending how much highway you travel, you would do better with at least 3.55 or 3.90
  4. expedite_it
    expedite_it Road Train Member
    1,646
    865
    Sep 8, 2012
    Does 18 spd stand for 18 speed? If not, what does 18 spd stand for?
    What does 6 nz stand for?
    What does 3.25 rears mean?
  5. expedite_it
    1,646
    865
    Sep 8, 2012
    Why is 3.55 or 3.90 better than 3.25 at that weight? I've been a company driver my entire career. I don't know what gear ratio means.
    Rideandrepair Thanks this.
  6. Oxbow
    Oxbow Road Train Member
    13,677
    141,841
    Nov 24, 2015
    What size tires?
    With 11r 24.5s I would prefer 3.90s or 4.10s with that weight in the hills.
    18 speed.
    6NZ is the serial # prefix for a Cat C15.
    3.25:1 is the rear end ratio.
  7. expedite_it
    1,646
    865
    Sep 8, 2012
    How did you people learn about rear end ratio in the first place? I don't think that most truck driving schools teach about rear end ratio.
  8. DUNE-T
    DUNE-T Road Train Member
    7,054
    17,193
    May 10, 2015
    Detroit, MI
    Just by reading this forum. Now you know also
  9. expedite_it
    1,646
    865
    Sep 8, 2012
    So is it the case that the higher the load that you are carrying, the higher the gear ratio that you need?
  10. Long FLD
    Long FLD Road Train Member
    12,918
    54,212
    Mar 4, 2015
    With a Cat and at those weights and running some hills. I’d want at least 3.70. That’s assuming you’re running 24.5’s off-road in the oil field. When I ran in the Northwest with a Cat we had tall 24’s and 3.70 rears, but our max gross was 105k.
    exhausted379 and Oxbow Thank this.
  11. North Pole Nightmare
    North Pole Nightmare Road Train Member
    1,015
    2,087
    Dec 15, 2021
    Those 10 year old Halliburton t800's had 4.36 gears I think,with 10 speed.Get up to 60 mph pretty quick,but limited to 62 or 63 mph.
    Crude Truckin' Thanks this.
