Gear Ratio
Discussion in 'Peterbilt Forum' started by rg2624, Nov 19, 2017.
  1. rg2624
    rg2624 Bobtail Member
    I have a short hood Peterbilt 378 C15 BXS 475hp 10 speed manual Eaton Fuller with 3.70 rears running lopro22's. I run long haul interstate mainly on flat roads pulling 30-45k loads usually going about 70-72 mph. Will switching to 3.36 rears make a huge difference on fuel economy as currently is not doing too well?
  3. Justrucking2
    Justrucking2 Road Train Member
    3,211
    4,295
    Sep 12, 2017
    Plymouth MI
    Yep, may want to go 3:40 ish or around there... Maybe 3:50 ish... There are calculators out there to figure it out. RPM vs Gear Ratio, that would be my first quest. I would call my local Cat Shop and talk with one of the guys there. Your particular motor is set up to a certain RPM for best fuel economy vs speed... You need to know those numbers from the factory.
    201 Thanks this.
  4. 201
    201 Road Train Member
    12,820
    26,400
    Apr 16, 2014
    high plains colorado
    I agree, higher gearing ( lower number) doesn't always guarantee better fuel economy. I drove a Century, 500 Detroit, 13, and 3:55's, and that's about as high as I'd go. 70 mph in 13th was like about 1500 rpms, (I'm convinced that truck would do 3 numbers), but for normal traffic, I found myself in 12th most of the time, and fuel mileage ( about 6.9 to 7.1) actually dropped a bit in 13th.
  5. wore out
    wore out Numbered Classic
    17,432
    216,969
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Google search Speed Calculator. There are several of them but you put tire size final ratio of trans, and rear ratio. It will give you the speed and rpm for any set up you want. To go to 3.55's from 3.70's is about 150 rpm. It's not enough to spend all that money on. The difference in 3.36 and 3.42 is about 75 rpm if that. Also if the rears are eaton then 3.36 will be your option. If they are Rockwell's then 3.42 will be your option. Personally I think you will spend a lot of money for to little gain. That's just an opinion
    Roger McG and Ruthless Thank this.
  6. cjb logistics
    cjb logistics Heavy Load Member
    766
    643
    Aug 13, 2016
    Liberal Ks
    wore out is correct, you will gain little with rear ratio. I have a 10 speed with 3.55, it was better for me to go to a 13 or 15 speed on paper then to change rears. If I would have made the change to a 13 as researched and planed back in January; I would have paid out the cost in 16 months ( if memory serves me). These numbers were based on 1.0 mpg +/- increase at 2.30 gal fuel. 24.5 highs
    Had everything ready to switch over but decided the 5k cost wasn't in the cards this year; just keep her around 65 now which does help a little, and watch my driving habits.
  7. p608
    p608 Road Train Member
    2,181
    2,993
    Nov 10, 2016
    Put taller tiers on it.
    Gsm Thanks this.
  8. rg2624
    Appreciate the input guys. I will look into the speed calculator. I need to find out the transmission ratio and use the calculator. I think looking into a 13 speed might be my best bet. On a side note my 2 turbos just went out. Are the refurbished ones worth buying or are new ones best? There is a $2200 dollar difference. Anyone have any experience with refurbished? I am only buying them from Rush.
  9. Diesel Dave
    9,733
    33,346
    Jan 20, 2010
    Hesperia, Ca.
    Look into the Borg Warner turbos. You can buy them out right brand new no core exchange for almost half the price of a CAT. And they are more reliable. I upgraded mine long ago. If you look in here for Turbos, you will see mostly everyone change over to the Borg Warner Turbos for performance. Goodluck....
