Gear ratio
Discussion in 'International Forum' started by Battleship, Jan 10, 2018.
  1. Battleship
    Battleship Bobtail Member
    30
    5
    Jan 10, 2018
    I'm looking at buying a brand new log picker truck because the old new 2005 just blew the cummins isx at 42000 hrs.
    I know in Ontario it's 105 km/h governed
    I was wondering with 22.5 tires how slow of a gear ratio you'd need to be doing 1800-2000 rpms at 105 in 8H.
    Ratios have to be slow anyway because we are regularly grossing 5-10% over 63500kg running northern Ontario.
    with 4:10s you can't get 8H over 1500 rpm before getting governed and we like running 1800 rpms ish at 105.
  3. Oldironfan
    Oldironfan Road Train Member
    5,776
    5,544
    May 22, 2017
    So maybe you need 4.33 axle gear I think.
  4. BoxCarKidd
    BoxCarKidd Road Train Member
    4,558
    6,645
    Aug 26, 2014
    Eaton Fuller road speed calculator. Put in your numbers.
  5. Battleship
    30
    5
    Jan 10, 2018
    So it turns out...with 22.5 tires just above 1800 rpm at 105 km/h, I need 4.56 gears...
  6. Oldironfan
    5,776
    5,544
    May 22, 2017
    That's odd. But I use mph.
  7. Battleship
    30
    5
    Jan 10, 2018
    It goes 65.1 mph AT 1800 which is 104._____ kph
