Gear Ratios
Discussion in 'Questions From New Drivers' started by AWaistOfAir, Mar 2, 2012.
  1. AWaistOfAir
    AWaistOfAir Bobtail Member
    15
    5
    Dec 25, 2011
    Sorry for asking this basic basic question, but looking at adds for trucks on the web, they all list gear ratio for the trucks. I though the gear ratio was set by which gear you were in.
    -Thanks
  3. Ezrider_48501
    3,845
    5,135
    Apr 2, 2011
    bismarck, nd
    it has to do with your drive axle gears, basically the numerically higher the gear the higher the rpm for each given gear selection. numericly higher gears (lower gear) give you better pulling where higher gears (numerically lower) give you higher speeds and typically better fuel millage. the trick is finding the best gear ratio for your given application.
  4. Ezrider_48501
    3,845
    5,135
    Apr 2, 2011
    bismarck, nd
    ie lower gears (numerically higher) are better for off road/ or lots of mountains where higher gears (numerically lower) are better if your running mostly flatland)
  5. Round2
    Round2 Light Load Member
    268
    90
    Feb 14, 2012
    WA
    You EZRIDER are a gentleman! It would have been so easy to insult that kid like most insecure windbags would have. Thank you! You give me hope for humanity.
  6. Lonesome
    Lonesome Mr. Sarcasm
    11,747
    24,523
    Dec 15, 2007
    Northern Indiana
    If I ever buy another truck, it's going to be 2:93's or similar.
  7. Round2
    268
    90
    Feb 14, 2012
    WA
    I guess the concepts of over and double over will be left for another time.
  8. oldmack
    oldmack Light Load Member
    52
    42
    Apr 9, 2011
    philadelphia, pa
    I have pretty good luck with 3:73's. I can pull the hill well enough and do ok on mileage at 65 in the flats with the engine at 1475.
  9. dirthaller
    dirthaller Road Train Member
    1,130
    13,529
    Sep 22, 2011
    Coloratah
    If you have an 18 speed and you like 3.70's you can go with 3.25's and run in 17th gear. Same with 3.55 vs 3.08's. Some guys are running 2.79's and running in 16th gear. Depends on what low end "crawl" gears you need.
  10. Pedigreed Bulldog
    7,737
    14,424
    May 7, 2011
    Personally, I like my 4.17's....and if I swapped 'em out for anything, I'd go to either a 4.35 or possibly 4.42 ratio.
  11. Round2
    268
    90
    Feb 14, 2012
    WA
    My old Puppy Dog had 3:70's and a 10sp Direct. I didn't need to light up the highway, just made money.
