Gear Ratios
Discussion in 'Ask An Owner Operator' started by Thotphobia, Jul 20, 2021.
  1. Thotphobia
    Thotphobia Light Load Member
    69
    47
    Apr 21, 2021
    Alright drivers, I haul logs currently, im looking for a another truck but I’m indecisive about the gear ratio, Im currently looking at a x15 565 with 3.70s and a x15 565 with 3.91. We rarely have uphills over here. Usually stay doing local hauls. i want 24.5s as well. What y’all recommend? Please help. They say 3.91s are big and are usually slower than the 3.70s.
    feldsforever Thanks this.
  3. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    How much off road will you be doing?
    Don’t know about logging, but I haul 140,000 lbs out of farmers fields. I have 3.91. Most guys have them here.
    Can do 70 mph but usually do 62 mph.
    Bean Jr. Thanks this.
  4. abyliks
    abyliks Road Train Member
    4,161
    9,819
    May 2, 2010
    ludlow MA
    3.90-4.33 should do it, easy on the clutch, and hopefully don’t blow anything else apart. Still able to run 70+
  5. AModelCat
    165,296
    If you're only hauling 80k with no hills or major off road 3.70 would probably be fine. Lots of soft ground, mudholes, uphill starts, heavy weight I'd go 3.91 without question.
  6. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,060
    Nov 18, 2014
    Land of local
    3.91s I'd go with for tall rubber. 3.70s would be geared a bit high off roading
    ProfessionalNoticer Thanks this.
  7. w9l
    w9l Medium Load Member
    316
    514
    Oct 12, 2013
    3.70 or 3.90 either one will work fine with 24.5 tall rubber. Like is mentioned, off road, mud, hard starts etc, 3.90 probably best. But with an 18spd I would think you would be fine with 3.70. I have a Cat and Isx both with 3.70's and tall 24.5 rubber and gross 85-92k most of the time. I often load miles off the pavement at farms and ranches and come crawling out through ledge rock and low water crossings. Then on the other end of the trip it is 70+ mph for hours. Both trucks handle it all fine. Had a truck that was 15spd 3.90 tall 24.5 and it was just winding a little much on the interstate with no real advantage to speak of at low speed.
    ProfessionalNoticer and Bean Jr. Thank this.
  8. ProfessionalNoticer
    2,941
    7,858
    Apr 25, 2021
    Tall 24.5s? If so, get a minimum of 3.90 if you have a 9/13/18 speed transmission.
  9. Thotphobia
    69
    47
    Apr 21, 2021
    Truck I was looking at was 18 speed
  10. mtoo
    mtoo Road Train Member
    1,942
    4,526
    Jan 15, 2011
    Retired on bended knee
    If you want a work truck get the 3.91 if you want a road truck get 3.70
  11. abyliks
    4,161
    9,819
    May 2, 2010
    ludlow MA
    how much highway? I’d really look at even a 4.10 or steeper
    our Tri axle has 4.56s with a 8LL and I can still get 75 out of it on tall rubber, let the pedal out and you are moving.
