Gearing and pulling, 3.08 gears with Mdrive in a Mack
Discussion in 'Mack Forum' started by Mattmanstroked, Feb 10, 2021.
  1. Mattmanstroked
    Mattmanstroked Light Load Member
    185
    279
    Nov 24, 2019
    Trying to get an idea of how some 3.08 gears are going to pull with a Mdrive and a 445hp in a Mack truck.
    This will be a road truck grossing close to 80k most times. Max speed of 70mph. Pulling tank trailers most of the time.
    Current truck has Cummins 450hp with 13 speed and 3.36 gears. It doesn't pull very hard.
  3. Concorde
    Concorde Road Train Member
    5,723
    20,453
    Jun 29, 2016
    West Melbourne Florida
    Your problem is low HP..450hp and likely low torque.
    For pulling heavy loads constantly I wouldn’t have anything less than 500hp.
    You have what I call a “Flatlander truck” :)
    TripleSix and Bean Jr. Thank this.
  4. Mattmanstroked
    185
    279
    Nov 24, 2019
    Man running a Mack in the logging woods has a 505hp Mdrive and 3.56 gears. Says he is running in Eco mode and it pulls plenty hard. They usually gross 85k or little more depending how close to the mill they are.
    Have driven a Mack with 445hp and 13 speed not sure on rear gears, they were low cause 70mph is like 1700rpm. It pulled very well.
    I just don't want to get another truck and it not pull better than the one I currently have.
  5. Sharky88
    Sharky88 Heavy Load Member
    715
    851
    Sep 25, 2013
    I have a Volvo with 2.64 gears 500 up 2050 tq it pulls very well. Mack and Volvo engines are the same just rebranded
    Mattmanstroked Thanks this.
  6. Truckwork2461
    Truckwork2461 Bobtail Member
    47
    15
    Feb 10, 2021
    Have you considered a HP upgrade? Shoot me your VIN and I can see what’s available. Some trucks it’s a matter of programming while others require part replacements.
    gekko1323 Thanks this.
  7. TripleSix
    134,527
    3.36:1 gears will pull worlds better than 3.08:1 gears ever could. For a freighthauler sticking with 80k GVW, ideal would be 500 hp, and 3.55:1 gears out back
  8. brysol01
    brysol01 Medium Load Member
    320
    460
    Nov 2, 2009
    i have a 2020 Mack MP-8 445C 12 spd M drive with 3:11 rears @1400 rpm
    i'm doing 68 just over 7 MPG, with summer fuel
  9. BobO1176
    BobO1176 Light Load Member
    142
    208
    Oct 29, 2021
    3.58 and 1350rpm at 62mph on mine. Perfect for my speeds.
    brysol01 Thanks this.
  10. brysol01
    320
    460
    Nov 2, 2009
    i am gonna drop it down , just over the line at 13350 is 65, and see if my fuel mileage improves some
  11. gekko1323
    gekko1323 Road Train Member
    1,700
    2,831
    Jul 14, 2018
    Henderson, NV
    Can you get the specs on any truck with the vin?
