Gen 3 Cab suspension.
Discussion in 'Volvo Forum' started by Weiboy718, Apr 6, 2023.
  1. Weiboy718
    Weiboy718 Bobtail Member
    47
    34
    Jan 25, 2017
    1F0CE2AC-C109-447B-8A25-B8E7B91AB81D.jpeg FF03899B-1B01-4216-A82F-564CBBF1020F.jpeg I just bought a new to me Gen 3 2019 VNL760.
    Anyone seen the cab airbag leaning to the right? It doesn’t seem like it’s affecting anything but the OCD in me wanting to get that straightened back out. If anyone has an idea on how to fix it pls let me know.
  3. loudtom
    loudtom Road Train Member
    1,717
    2,806
    Aug 26, 2016
    I fixed mine by replacing the front cab bushings and the torsion springs on the back. Mine is a 2012, so I don't know if is the same for your truck.
  4. Weiboy718
    47
    34
    Jan 25, 2017
    Thank you! I will assume that it is similar if not the same for the cab suspension etc. I will take a dive on those later.
  5. ducnut
    ducnut Road Train Member
    2,683
    8,131
    Dec 31, 2010
    SPI
    That cab is twisted on the frame. You can see it in the shock angles, as well. You’ll need the parts @loudtom used for his. Better replace the cab shocks, since you’re already there. I’d do the suspension shocks, too. It’ll make a world of difference, for not a lot of money. On my previous Volvo, a complete set of shocks was almost like driving a new truck, again.
    KB3MMX, Stringb8n, RubyEagle and 3 others Thank this.
  6. AModelCat
    164,647
    Definitely looks like your cab has shifted. Either worn out, bent or broken parts.
  7. Weiboy718
    47
    34
    Jan 25, 2017
    Thank you! I’m going to look into it.
    It looks straight by my naked eyes and it doesn’t ride any differently. I will look at all the bushings and torsion bars next week.
  8. loudtom
    1,717
    2,806
    Aug 26, 2016
    Volvo 23214277 Torsion Spring
    The torsion spring is the part with the bushing that goes bad, not the torsion bar. There should be two of them to replace.
    RubyEagle, ducnut and Weiboy718 Thank this.
  9. Weiboy718
    47
    34
    Jan 25, 2017
    Got it!
    This truck is a Penske fleet and it does comes with a 15 day warranty and I’ve already filed a complaint about most of the issues on the truck. Being hopeful they will pick up the tab on that but in case they don’t I at least have an idea where to start. Thank you to all you kind fellow truckers for the help.
    ducnut Thanks this.
  10. Weiboy718
    47
    34
    Jan 25, 2017
    This doesn’t look normal does it?
  11. ducnut
    2,683
    8,131
    Dec 31, 2010
    SPI
    No. The internal square tube should be on point, more counterclockwise from where it is.
    Stringb8n and Weiboy718 Thank this.
