General Lee question for the CB Repair Experts
Discussion in 'CB Radio Forum' started by shogun, Jan 4, 2013.
  1. shogun
    shogun Road Train Member
    6,075
    72,163
    Jan 23, 2009
    Doing a regen
    General Lee with 1969 finals in it, Atstaic 636L mike going through Predator 10-K dual coil short whip. Dead key is set to about 2.5 watts on low, 7 watts on high. When I start talking on the radio with the dead key on low, after a few minutes it raises up to 4 watts or so. The high side also starts climbing. Any clues as to why? It did no matter what antenna or power cord. What gives?
  3. kor b
    kor b Light Load Member
    254
    103
    Dec 16, 2008
    Are you using a cheap meter?
    Could be an unstable meter.
  4. shogun
    6,075
    72,163
    Jan 23, 2009
    Doing a regen
    No, its not the meter. I noticed it would move on the radio's meter as I talked for a few minutes, and it will go from keying 2 on the meter to over 4. I then tested it at my lieutenant's shop, and he has some very nice meters that confirmed it. The weird thing is sometimes the radio starts getting louder through the talk back and will squeal. After I let off the key for a few minutes it drops back down.
  5. Outlaw CB
    Outlaw CB Light Load Member
    260
    179
    May 26, 2012
    TR51 has been overheating and is likely leaky and thermally unstable. Often caused by many possible factors. Diode mods in the area on the bottom near the feet of TR51, or one in series with R238, and so on. Or R238 being changed to a value above 5,600 ohms. In short it may be going bad from excessive peak currents. A final or finals (if newer HP model) could be drawing excessive current. Antenna problems could have caused this to begin with. Or bias could be cranked too high by techs who do not really know the chassis. Poor antenna ground could be making the radio unstable. In any case TR51 is likely overheating and if leaky replacement is your fix, setting bias and other parameters properly, removing mods, and so on. You can replace the ceramic insulator with a large mica, clean everything and apply new heat sink grease. This gives better heat transfer out of it. Do not do this to the finals it will create too much capacitance from collectors to the wall. Best choice is a TIP36C. If metal tab you need to get the proper insulating hardware for the mounting screw, if plastic body then not needed. You will find they make both types. The extra capacitance will not bother it as TR51 only sees audio frequencies and the factory ceramic insulator really blocks heat transfer compared to mica. If TR51 is the problem you will notice talkback level is not stable, going from quiet to loud to actual squeal at times as it's temperature rises too high, especially if it is now leaky. In any case you need to find out why it went bad so the repair will last. As I stated mods especially combined with excessive bias or leaky finals are often the cause. Best before you replace things you talk on it checking first to see if one final is running hotter than the other. Usually you will notice lower than average power. If the finals are OK set the bias properly then move on to investigating TR51, of course inspecting for a diode swing mod in series with R238, or positive peak expansion (PPE) or negative peak compression (NPC) mods. Or one day you will be back where you are now.
    shogun Thanks this.
  6. shogun
    6,075
    72,163
    Jan 23, 2009
    Doing a regen
    Thanks for the info Outlaw. I know its not a grounding issue because it happened when I was running a 2x4 class c putting out 1100+watts with less than 10 watts reflect. The talkback does tend to get louder and squeal so I have a feeling your suggestion about TR-51 makes sense. I know my lieutenant told me that for some reason, one of my finals had higher voltage than normal, but the power output has always been consistent at around 45 watts. I know this radio is louder than other General Lee's out there, and it was purchased from Radioactive back in 2007. I will tell my lieutenant and let him test your theories out and get back to you.
  7. kor b
    254
    103
    Dec 16, 2008
    RadioActive has been known to volt
    the finals. I am surprised it has lasted
    this long.
  8. kor b
    254
    103
    Dec 16, 2008
    Wow your getting twice as many watts
    out of that box as you should be.
    Good job.
  9. Outlaw CB
    260
    179
    May 26, 2012
    Keep in mind SWR could still have been an issue, except in your case it was what the radio saw looking into a very poorly designed input circuit in the amplifier. The other comment about volting finals - yes crap mod but remember this removes most current flow from TR51. Meaning while the finals could still be the problem due to being cooked, this scenario is unlikely from consideration of the TR51 issue. It would have then seen only the 2166 driver current, unlikely to ever be able to overheat TR51. By the way my TR51 comments are more from experience over many years and not so much theory, except as it applies to diagnosing your radio sight unseen. So Radioactive is still doing those mods? Amazing, when will people ever learn.
    EZ Money Thanks this.
  10. EZ Money
    EZ Money Road Train Member
    Radioactive would never get my business.....I have read on so many forums the bad results from them.
  11. shogun
    6,075
    72,163
    Jan 23, 2009
    Doing a regen
    Outlaw, thats what I meant as far as theory goes, obviously you can't accurately diagnose the problem without seeing the radio in person, but your in-depth description tells me you absolutely have dealt with this issue before and know what you are talking about. We even set the radio up on his bench running it through his base antenna which has very low swr's also, and the deadkey started climbing on it. When I am able to get the radio to him and show him your suggestions, I will let you know what we find. Thanks again.
