Ghost on Trucker Drive Cam
Discussion in 'Other News' started by Graham Cracker, Mar 14, 2023.
  1. Truckers Report Jobs
  2. buzzarddriver
    3,859
    11,719
    Feb 1, 2011
    Dallas, TX
    The explanation i read was that it is actually a real person, but the frame rate of the camera caused it to appear transparent. But, if this was the case, why do the road side reflectors not appear blurry?
    Graham Cracker Thanks this.
  3. Bozwik
    Bozwik Light Load Member
    223
    398
    Mar 28, 2022
    Mars, USA
    And the fact that his last name is church... WHAT?
  4. Arctic_fox
    4,563
    26,018
    Sep 16, 2016
    Its a deer. If you freeze frame at the right point you can see the clear outline of it and the white on brown tail. Lines on the road and sign are quite blurry but the lines likely look a lot more fine then they are since they are.....well a solid mono colored line. And you can see the guys brights pop on just as another car with brights come around which likely combined with built in filtering washed out part of the frame.
    With my cheap dash cam i have seen simular effects. Had one at one point where a SUV cut me off and in the vid said SUV looked transparent just from both the shutter rate on the cam and auto filters even though it was a big green range rover.
    The Railsplitter Thanks this.
