Glass cleaning
Discussion in 'Experienced Truckers' Advice' started by Commuter69, Apr 19, 2023.
  1. Commuter69
    Commuter69 Road Train Member
    1,142
    635
    Jul 2, 2014
    I've had it with the cheap squeegees at the fuel lanes... they are useless with just water when you just went through farm lands and managed to collect several pounds' worth of B.O.B.'s(Bits O Bugs).....
    Does anyone have a good idea for a foaming type glass cleaner that actually works on bugs, preferably with some sort of a long reach spray? Thinking like a 'scrubbing bubbles' kind of solution.....
    Is there a foaming/scrubbing solution that can be put into a jug like you'd use to kill weeds with some type of pump handle to add pressure?
  3. mslashbar
    mslashbar Medium Load Member
    604
    822
    Jul 22, 2009
    elizabeth,co
    Mac's glass cleaner. Available at NAPA. Aerosol can then wipe off with paper towels
  4. Chinatown
    Chinatown Road Train Member
    77,896
    185,151
    Aug 28, 2011
    Henderson, NV & Orient
    Old fashion rubbing alcohol.
    4wayflashers and RockinChair Thank this.
  5. RockinChair
    RockinChair Road Train Member
    5,401
    14,543
    Feb 19, 2012
    Lubbock, TX & thereabouts
    Wet the windshield, then apply Dawn to the squeegee and wash as normal.
    In my experience, Dawn and water don't do well in a spray bottle.
  6. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    Best thing I've ever come across was a good foaming glass cleaner and really fine steel wool, wipe it away with paper towels. Unfortunately it makes scrubbing your bugs about 3 times the work it should be.
    Lite bug, D.Tibbitt and Rideandrepair Thank this.
  7. snowwy
    snowwy Road Train Member
    20,612
    13,333
    Jul 6, 2009
    I wash the window. Let it soak and wash and soak and wash. Or scrub. 3x. Then squee gee.
    It's not perfect but gets the job done.
  8. Flat Earth Trucker
    4,326
    16,699
    Nov 19, 2018
    I used to carry a telescoping pole brush. It worked well. So well, in fact, other drivers would ask to use it. I also carried a coiled garden hose which drivers would also request to use.
    One guy sprayed off the floor on the INSIDE of his tractor. Teams. Well, you know, teams.
    But, that was back when I had a 579, and I could put more crap and junk under the bunk. Nowadays, I'm driving a Freightliner, wearing flip flops, and blocking fuel islands.
    JoeyJunk, Lite bug, Speedy356 and 6 others Thank this.
  9. Kyle G.
    Kyle G. Road Train Member
    3,903
    20,582
    Jan 23, 2016
    Eastern Iowa
    What I do is wet the windshield with the squeegee, then let it “soak” while I walk around and do the side windows. Then I open the hood and climb up onto the steer tires and scrub the windshield with a short handle squeegee. Climbing up there gives you much better scrubbing power. After letting it soak a few minutes the bugs wipe off much easier. I can usually get all that done by the time the fuel pumps click off. Then I check the oil and stuff while the DEF pump runs. It’s my little fuel island routine LOL.
    If the squeegee water is particularly nasty, I will just spray it down with ordinary window cleaner, then use the squeegee.
  10. Commuter69
    1,142
    635
    Jul 2, 2014
    Does anyone know how well 'Simple Green' works as a WW fluid against bugs that don't have the brains to GTFO the way?
    Rideandrepair Thanks this.
  11. kwswan
    kwswan Road Train Member
    2,041
    11,225
    Jul 26, 2009
    mcminnville,tn.
    I use simple green in a spray bottle. Spray it on and let it soak a couple of minutes while I start fueling. Works pretty good.
    tscottme Thanks this.
