Going from Ohio to Alabama
Discussion in 'Questions From New Drivers' started by Jamal2017, Oct 6, 2019.
  1. Jamal2017
    Jamal2017 Bobtail Member
    4
    Jul 27, 2017
    Hi
    I’m a new driver and my first trip will be Sunday 10/6/2019. I’m going from Ohio to Alabama and I would like to know what’s the best route to take. I would like to avoid downhills if possible. I’m also carrying a heavy load and driving an automatic. I need all the advice and suggestions I can get. Wish me luck!
  3. stayinback
    stayinback Road Train Member
    3,911
    8,257
    Jan 24, 2014
    chicago,il
    Hi there Jamal.....
    It all depends where your at in ohio-
    Lets assume your starting right in the middle of the state (Columbus) ..Take I71 all the way to louisville- Then Jump on I-65 down to Alabama-(Depending on where in AL your going)...
    Its gonna have a few hills- But nothing too alarming- Your gonna have to get used to Hills-Because it wont be all flat roads.
    G13Tomcat and FlaSwampRat Thank this.
  4. truckdriver31
    6,998
    8,363
    Sep 18, 2013
    avoid down hills. lol
  5. Moosetek13
    Moosetek13 Road Train Member
    14,996
    19,063
    Nov 1, 2010
    Burnsville, MN
    Auto's are better with heavy loads going down hill than a manual.
    Learn the advantages of what you are driving.
    G13Tomcat Thanks this.
  6. 88 Alpha
    88 Alpha Trucker Forum STAFF Staff Member
    5,595
    18,185
    May 12, 2012
    SouthEast Alabama
    @stayinback is telling you correctly. There is a high probability you will go through Cincinnati. From that point, you can either go through Lexington, Knoxville, and Chattanooga or Louisville and Nashville.
    The Louisville-Nashville route is easier due to not having to go down Jellico. But, even that is not a bad hill at all.
    Learn your truck. In my experience of constantly hauling 47,000+ pound beer loads, the automatics worked pretty well, if you know how to use them. Set the cruise control on the speed you want to go down the hill and turn the engine retarder on. The truck will hold itself back. You may want to set your cruise 5 MPH below what you want to go down the hill at because on the Internationals I drove, the engine retarders didn't kick in until you were 5 MPH over what the cruise was set.
    I will also add, if you are planning on taking the Louisville-Nashville route, then going east on I-20 in Birmingham, pay attention to the detour signs in Birmingham. If the construction is still there, where I-20 East is closed, it is better to go on through town on I-65, then take I-459 North to I-20 East.
    G13Tomcat and Jenn72 Thank this.
  7. TripleSix
    133,654
    There aren’t any major hills between Ohio and Alabama. If you’re going to Birmingham Alabama, you take i75. You have a little hill climb at Jellico, at the Tennessee Kentucky border, but it’s not bad. Just gear down to a lower gear and turn on your jake brake if you have one.
  8. Jwhis
    Jwhis Heavy Load Member
    862
    1,356
    Jan 17, 2018
    Have fun in Crashvile
    firemedic2816 Thanks this.
  9. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    Sowwy, you will be falling down towards the Mighty Ohio. Then learning all about the Mount Eagle like a good trucker should.
    HE HE HE...
  10. Brandt
    Brandt Road Train Member
    4,635
    6,376
    Sep 17, 2012
    If you driving Freightliner with DT-12 auto transmission it's built for hills. It has more then enough engine braking power for any hill
  11. BRD TRANSPORT
    BRD TRANSPORT Light Load Member
    184
    69
    Jul 6, 2018
    Make sure brakes are adjusted ALL the time and go SLOW and you will be fine.
