going to give JB hunt a Try
Discussion in 'Ask An Owner Operator' started by The Real BRICKMAN, Oct 9, 2011.
  1. The Real BRICKMAN
    The Real BRICKMAN Light Load Member
    72
    27
    Feb 7, 2008
    INDIANAPOLIS,INDIANA
    :biggrin_2554: WELL , I talked to Bill about getting on with his company, will haft to wait so I'm going to lease on with JB and see how it goes .It will be local low per mile pay but alot extras load fee stop pay ect. I go to Chicago for orintation for 4 days paid 1300 for that after 1st load dels. I will be doing local out of indianapolis suppossed to be intermodul runs less than 125 mile radius figure if I can do 3 to 4 trips a day I should make at least 2000 or more net . :biggrin_2558:
  3. BigBadBill
    BigBadBill Bullishly Optimistic
    4,599
    4,439
    Oct 2, 2010
    Chattanooga, TN
    Oh man I'm sorry. I wish I could get a trailer and orientation together before the 24th. Intermodul work is a hard way to make a living. But I know the bills won't wait on what is happening with my company.
  4. The Real BRICKMAN
    72
    27
    Feb 7, 2008
    I just got to do something, hopefully if it don't work I can still give it a go with your company .Thanks for the info and help so far .:Cow wagon:
  5. BigBadBill
    4,599
    4,439
    Oct 2, 2010
    Chattanooga, TN
    Not a problem. Are you getting your own plates or getting them from JBH?
  6. The Real BRICKMAN
    72
    27
    Feb 7, 2008
    They provide them it no charge,But if it don't work out I plan to get my own before I leave them . I will try it for a 5-6 wks do the numbers, I need to make 2000 or better or I will be going back OTR
  7. SHC
    SHC Spoiled Rotten Brat O/O
    8,484
    7,047
    Feb 26, 2011
    Westville, IN
    I did local rail work with JB out of Chicago. i was able to gross $2500 a week and only spent $500 in fuel working MON-THURS. To make that tho, you will most likely want to work nights as that is the best time to get in/out of the rail yards w/o a wait.
  8. The Real BRICKMAN
    72
    27
    Feb 7, 2008
    Thanks for the info , Not sure if that will be the case for me I will be running based in indy .SO I'm her for orintation first surprise when I get to the hotel is (YOU KNOW YOU WILL BE SHARING A ROOM) or you can pay 20 bucks a night to have your own I opt,for my own will be trying to get JBH to pay that since I'M sure they know this is how it works but never let me know!!!:biggrin_2552:
  9. V8-MACK
    V8-MACK Light Load Member
    285
    112
    Aug 18, 2009
    Sounds like you did crosstown work, that,s where you make your money as an IC at JB. You need real thick skin, to do intermodal at jb. If you get upset easily you,ll never make it. Stuff like trailers loaded front to the back doors,to the ceiling, loaded over weight front,usually the rear of trl. A common thing at jb is trl lights missing,rubber grommets. Boxes set wrong not lining up with pins, you can pry the box over sometimes with a crow bar, this is not real common,but does happen sometimes. Just keep relaxed and don,t loose your cool with the rail road personnal, they have a supperior complex. I got along with them just fine,but I get along with everyone,and I knew what I was getting into. It,s a rr racket , tools needed are 8lb to 20lb hammer, spare mud flaps,get 3prong wire sets 4 all the different lights on chasis,landing gear handle. Learn spanish,russian,polish language.haha There,s alot of Mack trucks in rr yards for a reason, the intermodal trls beat a truck up, more than anyother trl. I drove a co. JB truck, my body was going to hell,so I had to leave, driving a 1976 r modal Mack is less abuse. I did Wi. to Chicago, rr to rr called crosstown is much easier. GoodLuck it,s not that bad,but it,s rr freight, alot more stuff to go wrong. I might buy a truck and lease onto Comtrac in the future, they have a decent program,from the IC ,s I talked to there. I bet you run into Wi. also,when they have 900 loads a day in Wi., your going to Wi. Honestly I,m not upset at JB, I,m just stating some facts. I knew the job was just a steady pay check, I knew there reputation, on there trucks,trls, huge weird safety program, heard about the Chicago terminal years ago. I can make more money elsewhere,and drive a truck with a better ride,presserving my body for the long term.
  10. SHC
    8,484
    7,047
    Feb 26, 2011
    Westville, IN
    Yes, I did crosstown moves but our radius was 150 miles of Chicago. I also did rail work with Schneider for 5 years prior to that so I already knew all I needed to make the $$$.
    Just be patient, cuz the first 2 weeks will be the toughest and drive you to the brink of quitting but don't, once u learn the in and outs of each yard, you will be fine.
  11. BigBadBill
    4,599
    4,439
    Oct 2, 2010
    Chattanooga, TN
    When you enter a new yard be sure to double check with everyone that you come in contact with about what you should be doing. many people will talk like what you are supposed understand and you drive around in circles. Until you know the lay of the land don't try and fix anything on the yard. UNION - and you are not qualified to change a light on a trailer. I did reefer containers and would get a talking to if I even cut the zip ties holding up the power cord from the gen set.
