good idle, no throttle
Discussion in 'Trucks [ Eighteen Wheelers ]' started by whiskeyone, Feb 20, 2014.
  1. whiskeyone
    whiskeyone Bobtail Member
    13
    Feb 20, 2014
    ohio
    97 3406E 5ek will sit and idle all day and control idle with cruise but no throttle at all. Was giving a bunch of different faults when running test with cc switch, but when hooked up to a laptop wouldn't read any codes. What next?
  3. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    CK. TPS. sensor and wire leading to it.
  4. whiskeyone
    13
    Feb 20, 2014
    ohio
    Check throttle position sensor, correct? Why wouldn't that show up as a fault code on computer?
  5. Chewey
    Chewey Light Load Member
    140
    72
    Feb 10, 2012
    Might be more of a mechanical issue with the tps....check mounting.
  6. whiskeyone
    13
    Feb 20, 2014
    ohio
    truck is out on the road and tps has already been changed, that didn't seem to change anything
  7. Chewey
    140
    72
    Feb 10, 2012
    what codes did you get?
  8. whiskeyone
    13
    Feb 20, 2014
    ohio
    was erratic, all different when using cc switch, but nothing on laptop
  9. wore out
    wore out Numbered Classic
    17,324
    215,081
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    You may check the round connector coming out of firewall to ECM. We have found wiring issues there on the older trucks. Usually a wire broke in side the insulation and you can't see it. I would do a pin test from TPS connector to ECM commector with a DVOM. Unplug the TPS sensor first with check for 5volts reference voltage and ground with a meter. the thrid wire will be signal from the TPS and will show nothing unplugged. Once you verify power and ground check sigan voltage by gently probing sig wire with test lead and the other to ground. Slowly push down on pedal and voltage should change slowly and gradually. This will tell you if you are missing power from ECM or ground. If the signal voltage is ok then you know your problem is in the signal wire from TPS to ECM.
    The truck side of TPS connector is where to check these voltages not the sensor side.
    baha Thanks this.
  10. whiskeyone
    13
    Feb 20, 2014
    ohio
    Thanks wore out, found a bad wire between firewall and ecm. Thanks to all for the advice!
  11. Chewey
    140
    72
    Feb 10, 2012
    Hi wore out,
    Is it my bad luck or are we finding more wires broke inside the insulation lately? I have found such wires at least 4 times in the last year:((
