Governor signal line
Discussion in 'Ask An Owner Operator' started by 77fib77, Dec 1, 2023.
  1. 77fib77
    77fib77 Road Train Member
    11,790
    78,153
    Jul 7, 2010
    St Louis
    So I have a truck that has the purge valve always going off. But it just started doing that.
    I took off the signal line. Air comes out near the governor. Plug it in poof, it purges. Is there always supposed to be air in signal line? When it drops below 100 psi, the air stops and the compressor kicks back in?
    Rideandrepair Thanks this.
  3. JB7
    JB7 Road Train Member
    1,063
    1,881
    Dec 13, 2022
    Laurel, MD
    The air in the signal line holds open the unloader valve when the pressure is high enough, about 120 -130psi. That way air is not pumped to the tanks when it is not needed. Once the pressure drops to about 100 the air is shut off allowing the unloader valve to close and the compressor to pump air to the tanks.
    Constant purging - these may vary depending on the make and model of dryer. What do you have?
    Excessive leakage
    Defectjve delivery check valve
    Defective governor
    Compressor unloader leaking excessively
    Tug Toy, Rideandrepair and 77fib77 Thank this.
  4. Big Road Skateboard
    7,251
    41,330
    May 2, 2021
    A pic of the governor and air dryer would make helping you easier.
  5. JB7
    1,063
    1,881
    Dec 13, 2022
    Laurel, MD
    Below provides more detail.
    "Is there always supposed to be air in signal line? " No
    As the system reservoir air pressure drops to the cut-in setting of the governor, the force exerted by the air pressure on the piston will be reduced so that the pressure setting spring will move the piston down. The inlet valve will close and the exhaust will open. With the exhaust open, the air in the unloader line will escape back through the piston, through the exhaust stem and out the exhaust port
  6. 77fib77
    11,790
    78,153
    Jul 7, 2010
    St Louis
    Well the signal line was cracked going into the air compressor. So the system cycled quickly. I fixed it. But i wonder if it will crack again the plastic line is brittle. But I have more new line and connectors, so ......
    JB7 and Big Road Skateboard Thank this.
  7. Big Road Skateboard
    7,251
    41,330
    May 2, 2021
    Very likely will. The older Pete's are having the same issues, but running 20-30 year old stratoflex. You can spray down the supply line to the governor and signal to the dryer with soapy water, and the both lines will be leaking the entire length.
    Whether stratoflex or plastic, I usually replace both with high quality plastic line, and don't use quick connect fittings at any of those connections.
    Cat sdp and 77fib77 Thank this.
