Greasin' up the VNL
Discussion in 'Volvo Forum' started by 86scotty, Dec 2, 2018.
  1. 86scotty
    86scotty Road Train Member
    4,718
    12,960
    Aug 27, 2017
    Appalachia
    2015 VNL780. I'm starting to do most of my own PM's at home to cut down on expenses. I'll have a pro look over it every 3rd PM or so. Oil & all filter changes no problem and I do thorough inspections since I own the truck but I was spoiled with fleet maintenance for too many years so I don't know all of the grease points.
    Surely this has been covered before. Can somebody link or give me a list of where the grease points are on a VNL?
    I know about the steering parts but don't want to forget any
    King pins
    steering box
    5th wheel
    Thanks
  3. dave14899
    dave14899 Bobtail Member
    13
    7
    Dec 2, 2018
    The king pins nipples should have one on the top and one on the bottom of king pins.
    There is likely a remote line to grease the throw out bearing in the clutch area. Don't forget the brake slack adjusters and s cam bushing nipples. Don't go to crazy with the grease gun on those. The drive shafts is likely sealed u joints, but the shafts may have a nipple for the slip joint. The steering box should have one nipple.
  4. 86scotty
    4,718
    12,960
    Aug 27, 2017
    Appalachia
    Thanks Dave, tranny is an iShift so no worries on the clutch. Truck has front discs as well but I'll look close to see if any part of the brakes have any zerks. First truck I've had with discs. It'll spoil you.
  5. Mudman78
    Mudman78 Light Load Member
    106
    108
    May 23, 2016
    Front leaf spring pins, king pins, steering box, tie rod ends, drag link ends, rear s-cam tubes & slack adjusters, 5th wheel.
    86scotty Thanks this.
