Greetings from Alaska
Discussion in 'The Welcome Wagon' started by Alaska76, Jan 20, 2014.
  1. Alaska76
    Alaska76 Road Train Member
    1,228
    1,653
    Jan 20, 2014
    Inland Empire, WA
    Hello!
    I encountered this site while doing some research on moving from auto mechanic for 25 years to truck driver due to a work related injury of my left shoulder and hand (the hand is fine) back in May of 2011. Two surgeries and complications along with concerns/lingering issues since 2011 have raised a few questions in my mind. I performed a physical capacities exam 1 year ago and had a "good day", meaning more than I will iterate , but in the end qualified for medium/heavy work, however, I do have limitations that I have come to recognize over the course of my recovery, the greatest being overhead work and long duration repetition.
    If things move forward in the direction they are now I will begin school in March/April for CDL A and every certification I can squeeze out of the Workers Compensation Vocational Rehab. I intend to get doubles, hazmat, tankers and any other peripheral available to increase my chances of employment.
    I have not had a moving violation since May 1986, no criminal record, no DUI ever, outstanding credit history, married 23 years and still going, will be 50 in July this year and tested very high in apptitude/academics for vocational evaluation. I hope this will benefit me when seeking a new employer.
    Keep in mind that I have always been fit and strong and kept active with exception to the above. Getting back to a "normal" level of activity has been a mighty battle, and I am winnning the war. I want to be as active as possible, physically and mentally, without overdoing it, otherwise I go nuts!
    Also, keep in mind that I am ignorant when comes the "lingo", so I ask that you avoid the use of acronyms, please. :biggrin_2552:
    The foremost question I have at this time is; What "specialty" type of hauling is the most physicaly demanding in descending order?
    I have in my mind, and correct me if I am wrong, that a tanker would be near the least demanding when compared to a reefer or dry van that required me to unload/load.
    Thanks in advance for your replies!
    Apologies to the Mods if I should have posted my question someplace else, feel free to move it as you see fit. :biggrin_25517:
  3. xlsdraw
    xlsdraw Road Train Member
    4,231
    8,737
    Nov 17, 2010
    Lake Alfred, Florida
    Reefers and dry van offloads? Not with most companies. All three are relatively easy. Flatbed might be a challenge.
    Alaska76 Thanks this.
  4. Moon_beam
    Moon_beam Heavy Load Member
    888
    1,289
    Aug 29, 2012
    Truck drivers are prone to carpal tunnel syndrome and rotator cuff injury to the shoulder. Are you intending to drive local out of Anchorage or Over The Road, (OTR)? If doing OTR in the middle of no where you may be required to change your own tire.
  5. Chinatown
    Chinatown Road Train Member
    77,780
    184,652
    Aug 28, 2011
    Henderson, NV & Orient
    Intermodal/drayage jobs are just drop & hook.
  6. Alaska76
    1,228
    1,653
    Jan 20, 2014
    Inland Empire, WA
    Would this be a likely option for a CDL newbie?
    Do you have any knowledge or theory as to why a truck driver may be prone to carpal tunnel? OTR is not likely unless it is to Prudhoe and back(if that actualy qualifies as OTR), otherwise it would be "local". My understanding is that things are quite different in Alaska when compared to the L48, thus part of the difficulty getting a true sense of what I may be in for.
    OK, I got the impression that load/unload is "somewhat" common, good to hear that it may be more the "exception, rather than the rule"? I am not confident my shoulder could tolerate pushing so much freight around, but I do continue to improve each day, so that may change.
  7. Chinatown
    77,780
    184,652
    Aug 28, 2011
    It's alway possible, put in the applications. Many companies say they want experience, but many also hire new CDL grads and don't advertise it.
    Alaska76 and HauntedSchizo19 Thank this.
  8. Alaska76
    1,228
    1,653
    Jan 20, 2014
    Inland Empire, WA
    That is my intention, as soon as I complete the courses.
  9. MrJSly
    MrJSly Bobtail Member
    Jan 21, 2014
    I attended NIT in alaska and got my CDL last Deceember it was a little slow getting a job but i found that smaller carriers are willing to hire people fresh out of school and train you. Thats what happened to me. I drive alot from Anchorage to Kenai/Soldotna and occasionally Homer. There is alot of flatbed work for summer construction loads.
  10. HauntedSchizo19
    HauntedSchizo19 Medium Load Member
    481
    148
    Dec 19, 2013
    Southern Tier, New York
    Most companies will start accepting applications within the last 2 weeks of classes, so they can get you started into orientation sooner; bare in mind that a lot of companies need to fill trucks, so this process will get the trucks filled, sooner. MOST companies won't hire a recent CDL graduate after 60 days of getting your license. They will want you to take a refresher course; therefore, costing you more money and time. Your best bet would be to start doing research on companies, calling these said companies, talking to your school, and putting in many applications.
    Best of luck to you!
  11. HauntedSchizo19
    481
    148
    Dec 19, 2013
    Oh, and tanker might not be the most physical job, but there is a lot of emphasis on safety. The trucks are different to drive, due to a high center of gravity and surge. The money is in the chemical bulk (HAZMAT) and oil, which tends to be more dangerous. Check out the different threads that are labeled: reefer, flatbed, and tanker. See some of the goodies within there. Oh, and listen to Chinatown, too. He's given me and others solid advice.
