Grinding Gears
Discussion in 'Questions From New Drivers' started by Iwant2driveallday, Mar 24, 2015.
  1. Iwant2driveallday
    Iwant2driveallday Light Load Member
    108
    41
    Dec 31, 2014
    Baldwinsville New York
    Why would I be grinding gears on a down shift? Would it be because my RPMS are not right or would it be because I am not positioning my shifts? Not sure what i'm doing wrong. any advice would help.
  3. Lonesome
    Lonesome Mr. Sarcasm
    11,767
    24,566
    Dec 15, 2007
    Northern Indiana
    Wrong RPM'S is the usual cause.
  4. RetiredUSN
    RetiredUSN Medium Load Member
    694
    991
    Jan 9, 2015
    I usually bump the pedal to bring the RPM's up, and when they are dropping, the shifter will hit the slot for me. It will take a while to figure road speed, and matching gears.
    JReding Thanks this.
  5. 12 ga
    12 ga THE VIEW FROM MY OFFICE
    1,568
    1,789
    Oct 21, 2013
    Central Michigan
    Your instructor should be able to coach you through this minor issue. Don't tell us your trying do do this without going to a recognized school, if so down shifting will be just a small problem in the long run.
  6. JReding
    JReding Road Train Member
    1,957
    3,511
    Sep 8, 2014
    Puyallup, WA
    The quick bump will work better if you're starting your downshift from a lower rpm, also. If you start your downshift anywhere from 1,000-1,300 (just for example), you've got a lot more "room" up top for the gear to slide in than if you start from 1,300-1,500... The higher rpm you start from, the closer you are to the engine's governed speed. Hope this makes sense...
  7. Iwant2driveallday
    108
    41
    Dec 31, 2014
    Our instructors just tell me to watch the tach. This is not a everyday problem for me but it's annoying. I go in one truck I shift great then the next truck I suck.
    They tell us let the rpm fall to 1100 clutch neutral rev up to 1500 then clutch into gear. JReding I am gonna try that out tomorrow and see if it works. I need to try something else out. The instructor I have is very good I think it's just me not understanding what I am doing.
  8. ArmyMP
    ArmyMP Light Load Member
    82
    21
    Dec 15, 2014
    Watertown, NY
    Practice, practice, practice. School trucks are very temermental. They are usually old and take some getting used to, each one is different.
    To get through school I over rev to about 1600 RPM and I gear fell in place when the rpms fell to 1500. I suffered though a ton of grinding because I was not reving enough.
  9. JReding
    1,957
    3,511
    Sep 8, 2014
    Puyallup, WA
    Your truck will only let you do it one way, but sometimes it's the technique you use that makes the difference; when I went to school, one instructor made me only look at the tachometer, which works, but I spent so much time worrying about that that I would end up losing too much speed trying to be precise, while another told me to give "the bump", and catch it on the way down, which works also, allowing you're not grinding into the next gear. This technique worked for me, until I got to the point that I can bump it in with no resistance or "scratching" at all, it just drops in.
    Iwant2driveallday Thanks this.
  10. Iwant2driveallday
    108
    41
    Dec 31, 2014
    Thanks guys for the help
    JReding thanks a ton I think i'm gonna try the bump and catch it on the way down. Think i'll be good. I was trying to be precise under revving or just totally screwing up today and it got to my head.
  11. 12 ga
    1,568
    1,789
    Oct 21, 2013
    Central Michigan
    When I was a CDL instructor I used to tell students that the need to down shift is accompanied with need to synchronize the speed of the transmission, by engaging the clutch, with the trans out of gear, raise the engine RPMS, depress the clutch and go to the desired gear. Remember it is perfectly proper to go down two gears at once. The fewer times you down shirt, the fewer opportunities you have to make a mistake. Most trucks have have a RPM difference in gears of 5-700 RPMS. Hope that helps some. Remember no one achieves perfection over night, some never do.
