Grinding noise when using Jake brake!
Discussion in 'Experienced Truckers' Advice' started by Odetozippo, Mar 19, 2023.
  1. Odetozippo
    Odetozippo Bobtail Member
    I have 2016 T680 Kenworth with MX13 motor. Replaced the turbo, charge air cooler and made sure all pieces of turbo shrapnel from previous turbo were cleaned out. My driver took truck from Michigan to Texas and back. Upon getting off of the highway, with Jake on he heard a grinding noise coming from the motor area. He claimed hearing same noise before the previous turbo blew. Could this be the turbo blades rubbing on the inner wall of turbo chamber? This is second turbo in 5 weeks. Anyone experience this issue. Is there a none cause? Any help appreciated
  3. Ex-Trucker Alex
    Ex-Trucker Alex Road Train Member
    1,552
    2,708
    Jan 7, 2023
    You want some help? Try posting it in the "Garage" subsection folders instead of here....
  4. Ridgeline
    22,750
    123,956
    where are you getting the turbos from?
  5. AModelCat
    165,007
    How did the original turbo fail?
